2006 Honda Civic suspension questions
Old Dec 28, 2014
msmith4's Avatar
msmith4 is an unknown quantity at this point
So with the unfortunate passing of my grandfather a couple months back I had an opportunity to pick up his 2006 honda civic lx with only 34k miles on it. I am thinking about doing a couple mods to it just to make it a bit for fun for whipping around the mountains in Colorado.
What I wanted to start with was suspension, I know I don't want to go as crazy as coilovers yet, but I would at least like some springs/sway bars to tighten up the ride.
Any suggestions?
-Michael
Old Jan 4, 2015
187on211's Avatar
187on211 is an unknown quantity at this point
Re: 2006 Honda Civic suspension questions
sway bar in the rear is easy but the front sway requires dropping the sub frame! working on my rear sway bar links atm. lowering puts more stress on the sway bar links and with winter here in canada i replaced back to stock for winter
Old Apr 3, 2015
johng35's Avatar
johng35 is an unknown quantity at this point
Dropping the subframe ? I had no such issues when I put my eibach on the front and rear.
you do need to change the rear upper brackets for the larger rear bar.
Best upgrade you can do for your car, and fairly simple.
Get a match set of front and rear and I would recommend eibach.
jessicakaybby
Apr 20, 2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
