Sponsored by:
Sponsored by: CARiD
High temp black coating header?
Old May 21, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
How is the high temp black coating kamikaze header from bigjoshracing.com. Is that header just as good as ceramic or chrome? Also will there 02 simulator that is universal work with our cars?
Thanks
Old May 21, 2003
Also is 245 dollars a good price for the header?
Old May 22, 2003
Chompondis's Avatar
Chompondis is an unknown quantity at this point
Ok, here it is. I just got dont putting my STOCK exhaust manifold back on cuz i had on a brand new kamikaze "high temp" black header. it sucks. it sounded like ****, we were spraying the bolts with lube and accidentally got some on the header. i went to wipe it off and the high temp paint came off like nothing. i then sratched it and it came off again. and as for the o2 sensors one of them will get fryed. i didnt notice until after i put the header on. we taped and taped and put all kinds of coating with tape and plastic on. it melted through all of it except for the last layer. good thing i took the header off in time. i only had mine on for one day. i hated it. and your check engine light will be on as well. unless you wanna become a ricer with a melted o2 sensor and fake high temp black header. go for it. Im gettin my money back later today so im straight on that shiiiiit. good luck homie
Old May 22, 2003
Chompondis's Avatar
i paid 230 for mine
Old May 22, 2003
azure's Avatar
Wow, it was that bad? The ceramic or polished aren't as bad though, right? I was planning on getting a Kamikaze header.
Old May 22, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
dude the kamikaze headr is sweet. dont bash it. it sounds like you half-assed your install anyway. as far as your engine light being on, get a freakin o2 simulator....PROBLEM FIXED. and as far the coating...yes the high temp black coating is cheezy...it eventually burns off. but it is more affordable to et the black coated header from kamikaze. but once again problem can be fixed. ever heard of JET HOT?? get it jet hot coated, reduces temperature, increases flow, garunteed for life, and looks good. it cost about 160 for sterling silver and about 185 for brillant blue. coating fixed. they coat the inside and outside of the header. so quit bashing the kamikaze header. its no point to do something if you arent going to do it right the first time.
Old May 22, 2003
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
aight lemme put my 2 cents in on the header deal.. i got a APC headers and i have zero complaints, sounds awesome and power is about the best i can ask for. yes it is a bit pricy but i like it.. i think i might be the only one..
Old May 23, 2003
Chompondis's Avatar
for one i didnt halfass my install. the biggest problem i had was with the sound. maybe its just me but i was never into the ricey sound that i got out of it.
Old May 23, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
aside from sound and installation problems, how was the PERFORMANCE?
Old May 23, 2003
Chompondis's Avatar
the performance was actually pretty good. i felt a lil boost from 35k. the gain was good. just the sound was shitty for me but thats maybe cuz it was a straight pipe and my exhaust...
Old May 23, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hm, so you didn't use a high flo cat ? ...
I was thinking just getting a kami. header w/o a cat but then I found out that getting a ticket in cali w/o a cat can cost 2g's ... T_T;;;;;;;
Old May 26, 2003
What exactly happend to the 02 sensor, and what did you tape and tape that melted through the layers? Please let me know.
Old May 26, 2003
bigjoshracing's Avatar
bigjoshracing is an unknown quantity at this point
Kamikaze Header
The black coating on the headers is just that, a black coating, if you spill brake cleaner or fluid on it chances are it will be eaten away, but good thing for black, just buy some hi temp paint from pep boys touch it up. Alot of guys scratch there headers or have rock dings, black is the easiest way to have a header if your not planning on being in a car show, if you scratch ceramic it stays scratched, same with chrome. Headers, regardless of whos brand wont make your car sound any diff. then it does now. The headers just allow more air to flow, bottom line you get a crappy sound if you have a crappy exhaust, sometimes shopping for the best deal and getting the 30.00 OBX muffler, ends up with a 30.00 Sound.
Old May 26, 2003
o2 wires
I hate to say, basic mechanic 101, lay wire on exhaust it burns, put plastic tape on wire lay on exhaust, it burns. Run wire off exhaust, no burn.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
autobots
Nov 29, 2001 07:27 PM
