Sponsored by:
Sponsored by: CARiD
type RS lip lit install HELP!!!
Old May 6, 2003
orion_squall's Avatar
Smile type RS lip lit install HELP!!!
hi,
I just got type RS lip kits. (looks like oem sedan kits)
The material is ABS.
I am trying to gather information concerning installing of the kit.
I have PDF instructions for installing 2DR lips kit, but it might be different fomr 4DR.
People, please give me all information you know, comment on ABS, comment on how to install, comment on issue I should worry and care...
thanks a lot!
I will make a DIy with all information you give!
thanks!!
Old May 7, 2003
dragoon's Avatar
its easy. the coupe instructions should basically cover it, but the sedan side skirts bolt into a different place, i believe. ABS plastic is one of the easiest things to put on because it bends.
Old Apr 6, 2004
whiteass's Avatar
whiteass is an unknown quantity at this point
where did you buy rs lip kit?
Old Apr 6, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
island motorsports? price?
Old Apr 6, 2004
invasian's Avatar
invasian is an unknown quantity at this point
i bought the spw type (r/rs)...
front lip - should just screw right on, there should be 2 screws on each side (behind front bumper in front of the tires). you could use adhesive if you want.
sideskirts - there are two front screws on each side (im guessing where the mudgaurds go?) and then there is the one in the back (a clamp) that is a pain in the a$$ to put on. the rear end of the sideskirt is only clamped on (not screwed) because there is a gap in the back where the screw goes. if you like to use adhesive you can, also you can drill holes on the bottom panel and screw the rest of the stuff they give you (bolts, metal plates, etc.). for mine, i just used adhesive and bolted the metal plates on the push the skirts down so that every time i open the door it wont hit the skirts.
rear lip - just the the front lip, except the screws go behind the tires in front of the rear bumper. you may use adhesive.
Old Apr 6, 2004
invasian's Avatar
you can get the lip kit at www.customauto.ca. they usually go for around $240-$350. i got mine for $240 at a local import shop.
97-DX-Lover
Jun 14, 2015 06:07 PM
Supramk3
Jun 11, 2015 11:13 AM
carid
Jun 10, 2015 09:57 AM
bo_red
Transmission
May 3, 2015 09:14 PM
