Sponsored by:
Sponsored by: CARiD
Leather Interior ................
Old Jan 16, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
Leather Interior
US $180.00 + US$25 S/H ................. Are those a real leather? ?? ??? if it's a real leather it's worth the $$ .....
Old Jan 16, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
DON'T YOU think the install would cost dough man......there is a place by my house that will do complete leather intsall in my coupe for $700(including leather)........I don't think thats bad considering its a 1500 dollar option from the factory!
Old Jan 16, 2003
blazed870's Avatar
blazed870 is on a distinguished road
$1500 option from the factory? I was told that Honda won't do leather on the civics.
Old Jan 16, 2003
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
Those are leather covers, they just go over your cloth seats to make it look nice.
Old Jan 16, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
i've always wanted to swap my interior for the interior of an acura 1.7el, if you could find one at a wreckers you could probably get the leather interior for for cheap.
Old Jan 16, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Quote
[hr]Originally posted by: JJJ
Those are leather covers, they just go over your cloth seats to make it look nice.[hr]
Actually, from the looks of it, you take off the fabric, and the leather goes in it's place. That looks pretty close to a katzkins kit.
Old Jan 16, 2003
mndthegap1's Avatar
Where in queens can you get the whole leather interior for 700 ??
as for installation ive checked around me in NY and the cheapest ive found just for
installation you provide the covers was 175 a seat.
Old Jan 16, 2003
adadani2001's Avatar
adadani2001 is an unknown quantity at this point
i tried searching on ebay for leather seat covers last week and all i could find was leather seat covers for other cars, but they do look nice!
Old Jan 16, 2003
XxSoVeReiGNxX's Avatar
THEY ARE CHEAP BECAUSE THEY ARE ONLY FOR THE FRONT.
Old Jan 16, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
if you read the ebay auction, it says it's for the front and the back
Old Jan 16, 2003
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
yea those are the kind that you take off the fabric and then slide the leather over it. I dunno but it also looks like the door inserts come with it too.
Old Jan 16, 2003
YS's Avatar
YS
i got the reply from the seller
Quote
[hr]They are leather/vinyl combo like all the other aftermarket seat covers.
They carry the standard 3yr. 36,000 mile warranty.
The maufacturer is DK-Schweizer www.dk-schweizer.com
Kristine
----- Original Message -----
To: <kez333@comcast.net>
Sent: Thursday, January 16, 2003 4:04 AM
Subject: Question for seller -- Item #2400314343
> are those real leather or vinyl( leather imitation) ???
> any warranty????[hr]
Old Jan 16, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
Groupbuy possibilty??
Old Jan 16, 2003
YS's Avatar
YS
i asked the seller againn if that leather cover is just a cover over your existing fabric or replace the fabric
if it a replacement of the fabric, i'm buying it
Old Jan 16, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
can this project be a diy or is it recommended that a profession install it?? does it require stiching or any special techniques to do it?
Old Jan 16, 2003
YS's Avatar
YS
here's a DIY for leather interior that i found on the Website ..... i forgot what's the website
Quote
[hr]
General Installation
Installation usually takes an experienced installer about 4 to 5 hours for an average two-row seating sedan with door panels.
Tools
The following tools will be necessary to install your leather interior kit.
· Hog-ring pliers
· Hog-ring cutters or tin snips
· Tool set (wrenches, screwdrivers, etc. for seat removal)
· Scissors
· 3M Upholstery Glue
· Tucking tool
Step 1): Removal of seats
You need to remove seats out of your car to install your leather kit. Seats are installed differently depending on the makes, models and trim levels, but in general they are bolted to the floor. Determine how the seats are installed and can be removed. Be careful not to make scratch or damage interior panels when removal. Also, make sure to unplug wires for power seats and/or seat heaters if any.
Step 2): Removal of cloth covers
The original cloth covers are held to the seats with many metal rings called hog-rings. To remove the original cloth cover, take the hog-rings out by using snips and detach the plastic parts from the seat frames. Later, you will need to install the leather covers exactly the same way as the original cloth covers are installed. So it is very important to remember where and how the hog-rings and the plastic parts are attached to the seat frames. Also, keep all the metal rods used in the cloth covers. They need to be used with the new leather seat covers later.
Step 3): Install leather covers
Insert the metal rods that you keep from the previous section in the corresponding locations on your new leather covers. Start installing leather exactly the same way as the cloth covers were installed. Place hog-rings to the same spots as the cloth covers.
Step 4): Put the seats back into the car
Put the seats back in the car. Be careful again not to make any scratches and damages in the car while putting the seats back into your car. Also, make sure that you tighten all the screws and plug all the wires.
Step 5): Door panel inserts (if any)
Remove the door panel from the door if necessary. Remove the door handles and the other parts from the panel if necessary. Remove the cloth cover from the panel if necessary and clean up the surface. Lay the leather inserts on the panel and trim the edge of the inserts carefully, not to over-trim. Tuck in the edges into the crevice with the tucking tool. Then apply appropriate of amount of glue after covering the surfaces that you don't want make a mess with the glue. Place leather inserts on the panel with avoiding wrinkles.
[hr]
Old Jan 16, 2003
how many of these leather seat covers are there available?
Old Jan 16, 2003
YS's Avatar
YS
Quote
[hr]
It is a replacement cover for the original factory cloth. The cloth must be
removed then this put on in it's place.
To: "kristine Brantley" <kez333@comcast.net>
Sent: Thursday, January 16, 2003 1:20 PM
Subject: Re: Question for seller -- Item #2400314343
> is that a leather cover or a replacement of the OEM fabric cover??
> Thanks
[hr]
yaaaaayyyyy ........... i'm buying it now ........ Woohoooo
Old Jan 16, 2003
wouldn't it be better to leave the fabric on before putting the leather covers over? this way it will give a more firmer feel. or is it better to just take the fabric off.
Old Jan 16, 2003
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
I guess I will shed light on this situation because I guess I'm the only one to do an EBAY kit on the site. The leather is leather, but its not like as soft as some leather is, its kinda rubbery? You know what I'm talking about. I bought the kit like a year ago for $270 shipped. You must take out the OEM cloth, and put this over it. Install is crucial, estimated $400-$500 worth of labor if you get a shop to do it. The Kit comes with the leather materical, and these staple things where you clamp the material to the foamy seats (makes it fit tighter). I didn't bother to use the clamping things, it just would have been so much more work. I just put the covers over everything. It's not tightly gripping the foam, but it definitely works. This process with a friend took 2 16 year olds about 13 hours of work. I say to you guys, it can be done by any average person, but don't expect to be driving your car for 2 days, maybe even 3 if you use the clamping staple things.
Here is a picture of what it looks like in my car....
Get a friend to help you, and prepare for a longgg weekend.
P.S. If you do the kit, you will then realize why I didn't use the clamping things. It was such a pain to pull the oem material off the seat because there were like 20 on each thing.
Old Jan 16, 2003
Subrage's Avatar
is that the black??? i hope it isnt
Old Jan 16, 2003
RegulatorRacing's Avatar
RegulatorRacing is an unknown quantity at this point
I cant find a way to contact the company, DK-Schweizer www.dk-schweizer.com, ive looked on the website but found only their number in Malaysia... anyone got a clue?
Old Jan 16, 2003
NytRyder2k2's Avatar
Bay Area
Aznnp77, looks good man. how much did that run you?
Old Jan 16, 2003
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: Subrage
is that the black??? i hope it isnt[hr]
Old Jan 17, 2003
Aznnp77's Avatar
it ran me $270 about a year ago.
Old Jan 17, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
heh i'll pass on this deal
Old Jan 18, 2003
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Looks good. But I paid $100 for my entire set (2 fronts & and back) and I have the actual seats (not just covers). Will be installed this spring.
Old Jan 18, 2003
Blk4blk2k1, where did u get ur seats and is that with shipping?? how does it looks; pics would help?
Old Jan 18, 2003
dru106's Avatar
ThE CoRRupToR
Thats nice but Im not sure if I want leather imo. Cuz my mom has a 2000 accord V6 and it has leather, when it comes summer time !! Damn burned my ***!!! lol. Plus in the long run it'll crack.
Old Jan 18, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i wish i had leather interior, if i had the money i would get it from LEATHERSEATS.COM check them out
INJEN
LEATHERSEATS
