Sponsored by:
Sponsored by: CARiD
Floor bar to prevent chasis flex
Old Dec 7, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
floor bar on ebay
hello people... have any1 of you have any experience with floor bars? one of my buddy said it works... "it prevents chasis flex... the frame" but i doubt his creditbility.. so what do you guys think?
yay? nay?
Old Dec 7, 2002
speedracersong's Avatar
never heard of floor bar before... it wont even fit on our civics. it says 88-00 civics.
Old Dec 7, 2002
cvc2k2's Avatar
its universal. it will fit. just basicly mounts on the bolts for the seatbelts... adjust... and it is suppose to prevent chasis flex. i dont know is it effective or not..
come to think about it... if we do mount this bar.. it will go ontop of the plastic panel.
on my friend 98 prelude SH.. it is carpeted.. so it wasnt a problem at all.
Old Dec 7, 2002
CapYoda's Avatar
Escaped Convict
I still dont think u really need anything like that.
someone on the site has it, and seems to like it, and thinks it does something...
but I still dont think u need anything like that. you're better off with a strut bar or something.
Old Dec 7, 2002
SpeedRacer's Avatar
SpeedRacer is an unknown quantity at this point
i got one. can't say its good for anything. its nice for the harness type belts. if i had to do it again, i don't know that i would have spent the money on it.
Old Dec 7, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I've got the arospeed one but I had to drill new holes in the mounting bracket because it didnt line up with th seal belt bolts, and I had to make some other minor modifaction but I got it to work. I dont know much it helped out because I have other strut bars but I think its cool to have one...
Old Dec 7, 2002
KeNsHiN's Avatar
LEVA
I've also got the arospeed one but I had to drill three new holes in the mounting bracket because they didnt line up with the belt bolts..................pissed me off!
Old Dec 7, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
SUMMARY:
Spend your money on something else...like a Neuspeed front upper strut tower bar or RSX rear anti-sway bar.
Old Dec 7, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
the general principle makes sense...
who knows if you can feel a difference or not..
Old Dec 7, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Looks like a Arospeed rip off or something. Your money would be better spent on something, like strut bars, or sway bars.
Old Dec 8, 2002
cvc2k2's Avatar
okay... it is kinda ugly inside your interior.. i guess i wont get it. i already have the nuespeed upper strut bar, rsx rear sway, obx lower tie.. im just waiting for the "Civic Type R" rear upper strut bar from ebay.
Old Dec 8, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: SpeedRacer
i got one. can't say its good for anything. its nice for the harness type belts. if i had to do it again, i don't know that i would have spent the money on it.[hr]
Good point. I might make myself a custom one since I'll be getting seats in the future...
Supposedly RS Akimoto has one out specifically designed for our 7th gens. I've never seen a picture of it though. The WW (Wings West) civic has it I think?
Old Dec 9, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
RICE, may have a effect on chassis, probably for looks, but it couldnt hurt, might even help, for under $75 try it out, let us know
Old Dec 9, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
I have the RS Akimoto floor bar. It's highly polished and is straight (no bend in the center for the previous generation civics). Mine mounted perfectly. Just had to take the seat belt loops off (just above the floor) and then mount them on top of the floor bar mounts. Used the OEM bolts cause they're extra long anyway.
Definite reduction in chassis flex (torsionally). No longer hear my sunroof squishing/creaking when I cause a twisting effect on my car by entering driveways/curbs diagonally.
I have all the other suspension goods as well so my car is quite rigid to say the least.
Current Set-up:
-Neuspeed Upper strut bar
-Neuspeed front OEM sway-bar polyurethane bushings
-Honda OEM '02 performance front mid chassis brace
-RS Akimoto floor bar (designed for 7th Gen civic's)
-Progress Rear Sway-bar/tie bar set-up
-Koni yellow inserts on all 4 corners
-Ground control in front/Neuspeed in back
-18" Centerline RPM's with 215/40/18 Yokohama Parada Spec II's
Terry
Old Jan 17, 2003
PunkingCivic's Avatar
I need TP for my bunghole
Well; I'm hella late on adding my commentry. I agree that the concept is good for the floor bar.
Universal? I hate that word when it comes to car stuff.
Universal means: that something will have to moded.
The foor bar will definately eliminate the chasis flex in the new civics.
With the flat floor board that the new civics have the body will more likely flex then the older civics with the hump going down the middle.
Its like fiberglass, the more curves you give the stronger it will be.
Make the fiberglass flat and apply some pressure it will brake. Hence, new civic swill flex more.
I'm going to take some mesurements.
Draw out the peices.
Buy the materials and have one welded together for less than the arospeed one currently available.
Well parts hunting people.
Late
Old Jan 17, 2003
Bellz's Avatar
Quote
[hr]Originally posted by: 3rdcivic
-Honda OEM '02 performance front mid chassis brace[hr]
I think I missed the discussion on this one. What exactly is it and where is this thing mounted? Does it do anything and a dealer price would be nice if you bought it there?
Old Jan 17, 2003
Bartkat's Avatar
When Honda designed the flat floor they compensated for the stiffness factor. The 7th gen is no less stiff than the previous model.
Besides, IMHO, if you add enough stuff to your car you could end up with a 3000 pound Civic. Now that would be slow.
If you want a "floor bar look", maybe put one of those clothes hanger bars only put it on the floor instead right under the roof. [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 17, 2003
3rdcivic's Avatar
As many people know now, the 2002's (not sure which models) came with an additional chassis brace that mounts to both sides of the subframe just under the powersteering rack. This is a piece that will fit with no modifications to the 2001's. It definitely helps neutralize some of the flex in the front of the car. Along with the Neuspeed Upper Strut brace and front Neuspeed swaybar bushings, and okay, the improved suspension, I've been quite pleased.
The RS Akimoto straight floor bar (to my knowledge) is not being produced anymore. I doubt they sold enough to make them on a regular basis.
TJ
Old Jan 18, 2003
Grey's Avatar
DIY King
Quote
The RS Akimoto straight floor bar (to my knowledge) is not being produced anymore. I doubt they sold enough to make them on a regular basis.[hr]
Yeah, that kinda sucks. It wasn't well marketed.
For the "Honda OEM '02 performance front mid chassis brace" check out the DIY's in my sig. It's the one labeled "oem part".
GolNat
Nov 27, 2018 03:32 PM
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
General DIY
Sep 25, 2015 08:02 PM
