Sponsored by:
Sponsored by: CARiD
5w-30 Mobile One
Old Oct 23, 2002
FiremanJoe's Avatar
FiremanJoe is an unknown quantity at this point
5w-30 Mobile One
So is anyone running 5w-30 syn in thier d17? The reason i ask is because both the people at the dealer where i bought it and a few other shops say to stick with the 5w-20, which sucks because there isnt much of a selection in that wieght. I live in maine so it doesnt get hot enough to use a thick oil and it can get sub zero up here in the winter, but mobile one is a great syn oil for both cold and hot, what do u think?
Also anyone know what the best aftermarket plugs are? I plan on changing them at my next oil change, 30k.
Old Oct 23, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
I'm running Mobil 1 5W30. No problems what so ever. It runs cooler and smoother. Only con is about 1 MPG, which I can deal with.
Old Oct 23, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
I use it. No problems either. For plugs go with denso iridium. A few users on here have them and like them.
Old Oct 23, 2002
FiremanJoe's Avatar
just wanted to know cause once i use synthetic u cant use regular oil thx
Old Oct 23, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Quote
[hr]Originally posted by: FiremanJoe
just wanted to know cause once i use synthetic u cant use regular oil thx[hr]
Sure you can.
Old Oct 23, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i use whatever the dealer uses. dealer changes my oil and filter ever since i got the car!!
Old Oct 23, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Quote
Who told you that???
Old Oct 23, 2002
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
HEFE... you can run into problems if u switch from regular oil to synthetic after 15k miles in da car. I dont wanna go into details.. but da engine will be used to da regular oil blend and switchin it to sumtin different is like changin sumtin's diet...
Old Oct 23, 2002
Hefe's Avatar
uh-huhhhhh........[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Oil is oil, whats soooo special about synthetic that you can't go back to regular..
I still don't get it?
Old Oct 23, 2002
PESTLNC's Avatar
I switched to synthetic on my old car at 128K miles...no problems.
The theory behind this is: Since synthetic is more "slippery" and has smaller molecules it has a better chance of getting past the seals and being burnt.
Old Oct 23, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
Happy Mobil 1 user here [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Going to change my oil tomorrow. $17.88 for a 5-quart container
Old Oct 23, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
ARGH...
Okay. Non synthetic oils leave micro deposits in your engine and on your valves. Over years this can build up and can account for some lost HP and blow by in the engine.
How do you avoid this? Well additives to your fuel helps, but it only delays the action, not prevents it. The only way to prevent it is to use 100% synthetic from day 1 and never switch. As soon as you switch the deposits start to build up. Also if you switch from mineral based oils to synthetic, its not going to reduce the deopsits already in there, it will just prevent more from forming.
Will it hurt your engine to switch from either? Absolutly not.
Does the loss of power warrent buying full synth for 5 years (which is where you will start seeing a difference in power)? Not if you own a daily driven non turbo/nitrous civic.
On a second note, synthetic oils work better (ie keep viscosity) at higher temps/stress, so its a good idea to use these for FI and N20 applications as well.
Old Oct 23, 2002
Hefe's Avatar
Thank You Joe.... Here = [IMG]i/expressions/beer_yum.gif[/IMG]
Well said
Old Oct 23, 2002
Bartkat's Avatar
I'm using Motorcraft synthetic blend. It comes in 5 W 20 and I'm getting a bit over 1 MPG better gas mileage.
Spark plugs = Denso Iridium IK20. Runs smooth, can tell the difference.
Old Oct 23, 2002
Shawn02's Avatar
Shawn02 is an unknown quantity at this point
So what would switching to 5w30 do?........[IMG]i/expressions/face-icon-small-confused.gif[/IMG] I know the manual says to use 5w20 and if you use 5w30, then switch back....but if 30 wasn't bad for it, then why would they say switch back?....
Old Oct 23, 2002
JoeB16's Avatar
the oils weight is determined by the enviroment you drive in. a thinner oil will be more prone to freze in sub zero temps.
Old Oct 23, 2002
Hefe's Avatar
Quote
[hr]Originally posted by: JoeB16
the oils weight is determined by the enviroment you drive in. a thinner oil will be more prone to freze in sub zero temps.[hr]
That's why here in Texas i use 5W-30 and not 5W-20.. because i don't like to use the thinner oil in 110 degree heat, i like the better protection and thicker oil for down here
Old Oct 23, 2002
dragoon's Avatar
i'll switch to synthetic when/if i swap to a k20. and that's not gonna be for at least a couple years, anyway.
Old Oct 24, 2002
klam's Avatar
klam is an unknown quantity at this point
Quote
Well, technically it doesn't "freeze" but it gets thick like molasses.
However, synthetic will keep less viscous when it gets cold and flows easier. It will negate any effect from the increase in viscosity from 5W20 to 5W30 which isn't much.
Some oil analysis has found that Mobil 1 is on the "thinner" side of a 5W30 oil. While Amsoil's 5W20 is on the thicker side. The actual difference between Mobil 1 and Amsoil is less than the 5Wxx number suggests.
Old Oct 24, 2002
sumama's Avatar
sumama is an unknown quantity at this point
What do all the Californians use?
GolNat
Jan 12, 2021 09:06 PM
GolNat
Nov 27, 2018 03:32 PM
Misfit2613
Jul 30, 2015 09:49 AM
