Sponsored by:
Sponsored by: CARiD
Double check my shopping list...
Old Oct 10, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Ok, first time I ever changed oil.... Could you please tell me if I'm missing something
4 quarts of Mobil 1 5W-30
Fram Extra Guard Filter (PH7317, I'm assuming the filter for the D17A1 is the same as the D17A2)
Oil drip pan (the thing you drain oil into)
Strap type filter wrench
rubber gloves
Already have a jack and stands if needed
Is that everything I need? if not, please add what I'm missing, thanks!
Old Oct 10, 2002
Youthachak's Avatar
Youthachak is an unknown quantity at this point
Your missing the replace-able washer but im pretty sure you could use it one more time.
Old Oct 10, 2002
Youthachak's Avatar
oh yea, and your strap filter might not fit/strap onto the stock oil filter. I had to use one of those big plumbers wrench thingy the first time because it was on so tight. My second and third oil change i had to use all my might getting it off with my hands and ummmmm.........I think thats all. Good luck.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Oct 10, 2002
taz757's Avatar
What ^he^ said, but you're gonna hafta get it from the Honda dealer. It shouldn't be more than a buck. You *can't* reuse these things as it's a crush washer. You take out the bolt and the washer is gonna be all mashed out.
edit: Also, when you install your new filter and plug, turn it 1/4 turn past tight. Any farther and you'll end up stripping it out and then you're looking at replacing your oil pan.
Old Oct 10, 2002
Vesper's Avatar
Vesper is an unknown quantity at this point
its called a lock washer. and belive it or not but any honda d series motor or b series motors oil filters will all fit each others.
Old Oct 10, 2002
Jap-Euro Fusion
Alright thanks guys.... I'll just buy a bunch of these washers so I don't have to go up there and get one every single time. I think I have a Monkey wrench downstairs, but if not, how much is this "Honda wrench" they talk about in the manual?
One more question... I was reading the manual again, it doesn't say anything about a washer with the filter... Just with the drain bolt. Is this what the lock washer is for? or is the manual missing something?
aZnVoYCe
Dec 7, 2001 12:41 AM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
