crazy CUSTOM ISSSHH!!??
ok i was thinkin about bout a custom exhaust mod but i need an opinion for the future. would an exhuast commin out the rear side rie in front if the rear tire look AIGHT or wut? i would want it with like a flat rectangular tip
if you have your car lowered its gonna be pretty close to the ground, you may scrape!
in my opinion, it looks good on saleen mustangs, but on a civic, i dunno.....
but its your car, if you want it, them more power to ya
If you wanna do that then just put a "Y" in the main pipe and run your pipe out the side and put a cap on it. Then when you want to make noise, take off the cap and you will be running a straight pipe out the side. When you want to be legal, just put the cap back on your side pipe.
I know that, at least here in VA, the exhaust has to be vented out behind the passenger compartment of the car. As long as you bring it out behind the doors, you'll be fine.
As for doing this mod, I think it's one of the dumbest things you could do. It just wouldn't fit with a little 4cyl car.
