problem with altezza please help
well yeah i bought some altezza for my car i personally think they look good and the ppl that ve seen my car say the same anything
anyways the problem is one of the altezza fogged up when i can do so it wont happen again
can anyone help
thanks!!
can anyone help
thanks!!
rp, mine fogged up also, the only thing that worked for me was I used silicon and sealed up the outside really well, and in the winter, I change back to the OEM lights just because of the poor manufacturing and they are very expensive, if you are buying them a lot. I would say take them out for the winter, i guess that only applies for the northern regions, but definatily use silicon and reseal the lights, don't take them apart though, they are too easy to break. hope this helped.
take the lights off
use a hair dryer to dry up the fog on the lenses, do this bye pointing it into the bulb holes
once the fog is all gone, use CLEAR silicone to seal up the edges....
again i stress use CLEAR silicone, someone else i knew used something else and it dryed yellos....looked like ship!
good luck
good luck
There are some little nylon plugs that go into the fender wells underneath where the tail lights fit. Make sure those are in place. If one or more is missing, you'll get moisture to the inside of the tunk and fog the lights. If you don't have a plug, fill the holes with silicone. You should be able to see these holes/plugs by removing the tal lights and looking down into the area where the bottom/front of the light housing fits.
Quote
[hr]Originally posted by: LuvDatCivic
Silicon...My rears are ok so far but I sealed my headlights with silocon and I take it through the carwash without any problems.[hr]
CrEePin01CiViC
Dec 31, 2001 11:09 PM
