Sponsored by:
Sponsored by: CARiD
oil filter wrench
Old Aug 27, 2002
odie's Avatar
odie is an unknown quantity at this point
oil filter wrench
i'm going to change my own oil for the first time
(had the dealer do it the first 4 times), and will
be using a brand of oil filter that has a nut at the
end of the cap, so you don't need to use a
special oil filter wrench. problem is, the filter
that is on there right now is a Honda filter. is
there a way i can get it off without the special
wrench? i dont want to buy one just to use it
one time. also, i'd rather not use it once and
return it to the auto store.
Old Aug 27, 2002
otep12's Avatar
otep12 is an unknown quantity at this point
Get large rubber bands and tie them around the filter. From there you can take it off with your hands.
I use surgical gloves for gripping the filter.
Old Aug 27, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
How about trying a little bit of muscle....should come off.
Old Aug 27, 2002
odie's Avatar
Thanks for the info fellas.
I wasn't aware that the filter should be loose enough that I could unscrew it with my hands.
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 27, 2002
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Dealers love to tighten them so tight that people can't get them off without tools....thus you go back to them to get it changed...
Matt
Old Aug 27, 2002
Freak's Avatar
Freak is an unknown quantity at this point
Just in case you didn't know make sure the engine is nice and cool, if not watch out for the burn...[IMG]i/expressions/face-icon-small-wink.gif[/IMG] but that way it's easier to remove the filter with some rubber gloves or even gettin somethin rubbery and wrap it around the filter to give it a nice crank...peace and have fun
Old Aug 27, 2002
aferenz's Avatar
aferenz is an unknown quantity at this point
and you shouldn't need any tools to put it back on always hand tighten. I just use a wrench to get it off.
Old Aug 27, 2002
wawacito's Avatar
wawacito is an unknown quantity at this point
yea the dealer tightens it reaaaaaaallly hard - i hate it. I couldnt get it off with my hands so this is what i did ... reaaaaally messy but what can you do?... I drove a screwdriver through it with a hammer and and used the handle to spin it off. reeeealy messy. make sure you drain as much oil as possible before doing that.
Old Aug 27, 2002
LiKEaFeRiO's Avatar
Use a belt and wrap it around the filter then tug hard on the belt with one hand and the other on the filter. I use an old leather belt and it has never failed me.BELT
Old Aug 27, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: LiKEaFeRiO
Use a belt and wrap it around the filter then tug hard on the belt with one hand and the other on the filter. I use an old leather belt and it has never failed me.BELT[hr]
Go to the oil change place one more time and have them put your new filter on hand tight. Then you can get it off next time ok and keep on changing yourself.
Old Aug 28, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
There's a reason why the dealer tightens it so tight - it's to prevent oil leakage. If you look closely at the instructions for the OEM Honda filter, it says to tighten it a certain # of turns (which is much more than handtight).
Old Aug 28, 2002
Quote
[hr]Originally posted by: odie
return it to the auto store.[hr]
You could use a large wrench to take the old filter off. Keep in mind that the old filter will probably be dented and punctured using this method, but you're just going to throw it away anyways so it doesn't matter.
RIPSAW
Nov 6, 2015 04:36 AM
Unleaded
Jun 26, 2007 09:25 PM
avenger
Feb 11, 2002 07:00 PM
02Si
Bolt-on Engine Performance
Jan 7, 2002 11:35 PM
02Si
Jan 6, 2002 09:18 PM
