Sponsored by:
Sponsored by: CARiD
does anyone have pics?
Old Aug 7, 2002
lilbluecivic's Avatar
lilbluecivic is an unknown quantity at this point
i have had my dc stainless steel header for a couple of months now, and it is starting to look like sh*t. can some people that own the stainless steel header post some pics so i have something to compare mine to? and does anyone know if this would be covered under warranty?
Old Aug 7, 2002
C2i0v0i1C's Avatar
SuperMODrizd
i have ceramic but i know they change all colors, purple and blue and things like that
Old Aug 7, 2002
Bartkat's Avatar
It's galling from the heat, man.
Old Aug 7, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
All chrome header's (pluaral) are going to change colors due to the exhaust heat thats flowing through them
Old Aug 8, 2002
dragoon's Avatar
i think you can use high heat engine paint (not the 500 degree, the 1200 one) to make it whatever color. i'm pretty sure the header on our cars will not hit 1200 degrees
Old Aug 8, 2002
Bartkat's Avatar
If you paint em black they will give off infra red radiaiton and run cooler.
Old Aug 8, 2002
supercivic's Avatar
supercivic is an unknown quantity at this point
hey bartkat, is that the Tenzo R front strut bar? and it fits with the intake?
Also, DIY intake? do you mean you installed it yourself or you what?
Old Aug 8, 2002
i know it changes color, but on 3 of the pipes it looks like it rusted. i polish it and most of it comes clean, but after driving it around it goes right back to how it was
Old Aug 8, 2002
plastic's Avatar
plastic is an unknown quantity at this point
why don't ya buy some heat wrap from (optauto.com) to cover those ugly spots and to run cooler
Old Aug 8, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
Stainless will rust....although I'm surprised about the 3 month time frame????????? Usually it takes much longer....especially during dry summer months........still, it should perform better than that...BTW, you may be cleaning slight oxidation off (rust)...anyway, post a picture for us to better see..peace!...I've got ceraminc as well.
Old Aug 8, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: supercivic
Also, DIY intake? do you mean you installed it yourself or you what?[hr]
That's a "no name" bar from Auto Dynamic that fits far enough forward and is tilted so it clears the intake by about 3/4 inches. The intake is a K&N FIPK. "Fuel injection performance kit". I need to change that in my listing.
The DIY that I did before I got the K&N was to remove the stock intake, all but the filter box and then run a flex hose to the point where the original intake sat behind the battey on top of the inner fender. It worked really nice, but was kinda ugly.
Old Aug 8, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: plastic
why don't ya buy some heat wrap from (optauto.com) to cover those ugly spots and to run cooler [hr]
Heat wrap will hold the heat in. Usually you use that on things like intakes that you want to keep engine heat out of.
Old Aug 8, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: lilbluecivic
i know it changes color, but on 3 of the pipes it looks like it rusted. i polish it and most of it comes clean, but after driving it around it goes right back to how it was[hr]
Use something like Flitz or Simichrome polish to clean it up. Then make sure it's really clean and then spray or wipe the area with high temperature silcone. That will coat the area and prevent oxidation. You might want to check and reapply the silicone every once a week or so.
We've done this on motorcycle header pipes, that are real bad to turn colors and oxidize. The silicone will put a barrier to air, and it is the air and high temp that is causing the problem.
Old Aug 8, 2002
thanks for the info eveyone, i wish i could post pics but i dont have a digi cam. should this be covered under warranty?
Old Aug 8, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
its from the heat, i dont have headers so i wouldnt know what to look for
Old Aug 8, 2002
injencivic's Avatar
sorry i couldnt help you
GolNat
Nov 27, 2018 03:32 PM
ricer_em2
May 11, 2016 08:09 PM
thatcham
Sep 30, 2015 08:28 AM
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
