Sponsored by:
Sponsored by: CARiD
Good Oil Filter?
Old May 30, 2002
klam's Avatar
klam is an unknown quantity at this point
Good Oil Filter?
it is suspected that Honda's OEM oil filter is a Fram. According to some reviews, Frams are subpar filters.
Who else makes filters that'll fit our cars? Bosch?
Old May 30, 2002
Bartkat's Avatar
There are all sorts of brand name and noname filters that fit our cars. Just pick the one you like. There's not a darn thing wrong with the Honda label filters. You think Honda wants all their cars going bad because they certified a bad filter?
Old May 30, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
i have a bosch on right now.
Old May 30, 2002
Collective's Avatar
Collective is an unknown quantity at this point
Mobil 1.... but at $13.00 a filter it better be good ! [IMG]i/expressions/laugh2.gif[/IMG]
Old May 30, 2002
Mbow's Avatar
<< There are all sorts of brand name and noname filters that fit our cars. Just pick the one you like. There's not a darn thing wrong with the Honda label filters. You think Honda wants all their cars going bad because they certified a bad filter? >>
I think that is about all that needs to be said....I wouldn't spend the money on anything else. Honda is known for quality and they most certainly wouldn't put a subpar oil filter on their engines.
Old Aug 21, 2002
odie's Avatar
odie is an unknown quantity at this point
There's a cross section of the Honda OEM filter at:
http://handa-accessories.com/filterlrg.jpg
The filter is paper. From what I've read in this NG, aren't
paper filters supposed to be pieces of crap? Is Honda
using a low quality piece of crap filter?
Old Sep 18, 2002
Grey's Avatar
DIY King
Thank you for the link. I missed this thread when it was first posted. I've been buying the Honda filters made in Canada.
I found an AutoZone that's close by and from now on I will only buy STP or Bosch filters.
Old Sep 18, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Go with Bosch, they make good filters. I have one on my car right now with new Mobil 1 Syn and my car runs alot smoother, probably just the syn though. The Bosch filter that fits our civics is 3323 last time I recalled.
Old Sep 19, 2002
GoOkStA's Avatar
GoOkStA is an unknown quantity at this point
man, it dont matter wut oil filter u have, they all the same, just wut name brand u want?
Old Sep 19, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: GoOkStA
man, it dont matter wut oil filter u have, they all the same, just wut name brand u want?[hr]
man, clik on da link posted by klam, they all not the same, you jus read it?
Old Sep 19, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Running Bosch now and every oil change...nuthing like good German engineering!
2Hottie
Old Sep 21, 2002
Conan's Avatar
Conan is an unknown quantity at this point
I've been using the HAMP oil filter by honda. Not sure if it was the filter or not, but my gas milage is a little better now. http://www.inlinefour.com/honhamoilfil.html
Old Sep 21, 2002
RunawaySoul's Avatar
RunawaySoul is an unknown quantity at this point
Has anyone used Purolator? I hear they are great.
Old Sep 22, 2002
Bartkat's Avatar
Something the NTPOG filter evaluatiion doesn't consider is the pore size of the filter media. Smaller pore size with a too small filter media area can lead to higher pressures which will either force "dirt" through the filter, or the pressure can open the bypass, and allow dirt to get past the filter. Either way, the result is unfiltered particles circulating through the engine.
In order to use a finer filtration (smaller pores) without higher pressures, most filter makers will increase the area of the media, thus reducing the pressure from the smaller pore sizes. It all ends up being a balance between filtration efficiencey re; particle size retained, and the amount of filtration area,, determined partly by the overall size of the filter.
When the author mentions stiffer bypass valves, this may very well be an indication that those particular filters may operate at higher pressures. Thus they make their bypass open at higher pressures. Higher pressures may lead to particles being forced through the filter, and more resistance to oil flow in general.
So when considering what is the best filter, all other things (quality, construction, materials) being equal, the filter area plus the filter pore size must be part of the selection process.
I believe that the NPTOG article is accurate and useful as far as it goes. It just doesn't go far enough. Once the best quality filters are selected, then there are areas not covered by the article that must be considered.
Old Sep 22, 2002
Bartkat's Avatar
If you are real serious about oil change intervals, filters, etc and wish to do some testing, oil samples can be sent to Blackstone labs for oil quality and engine wear analysis.
Blackstone Laboratory
Old Sep 22, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
K&N oil filter is great
Old Sep 22, 2002
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I use Wix. I'm happy with it.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
RIPSAW
Nov 6, 2015 04:36 AM
docmartin14
Jul 30, 2015 11:26 AM
superstanko
Apr 28, 2015 04:38 AM
Unleaded
Jun 26, 2007 09:25 PM
