Is it worth getting a anti-sway bar (upper strut bar)???
thinking of getting a neuspeed ones, does it make the ride better, i lowered my car with neuspeed sports
Well an anti sway bar is something completely different than an upper strut bar. I would actually recommened getting both, depending on if you want to increase or decrease your over or understeer, which will determine if you get rear or front of either.
On my Civic, I have a DC Sports front upper strut bar, a DC Sports rear lower tie bar, an Acura RSX Type S 19mm rear anti sway bar, and I have on order a DC Sports rear upper strut bar. Also looking for an upgraded front anti sway bar as well. These parts compliment my Koni struts, Ground Control coilovers and my Ingalls camber kits. Car handles VERY nicely.
Escaped Convict
depends on ur handling preferences.
suspension tunning is, for most part, striving for neutral handling...
anti-sway bars, depending on if you're getting front or rear, and depending on its thickness, will yield different results. they not over create oversteer or understeer, they factor in other driving charactertistic too.
do a research on it.
upper strut bar is mainly to prevent chassis flex.
know what kind of handling u want, and then go for the right suspension setup.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
MamaBear2015
Aug 25, 2015 10:47 AM
Amulon
Aug 18, 2015 11:03 AM
fordover
Jul 11, 2015 09:10 PM
