Sponsored by:
Sponsored by: CARiD
Projectors, Dont Know What To Do.....
Old Apr 17, 2002
cro2k2civicla's Avatar
cro2k2civicla is an unknown quantity at this point
I am having all kinds of trouble with my CK projectors, same as matrix and others. I cant seem to get them properly aligned. I have this dark blue line across the driver side and a faint blue line across the passenger right in the light pattern. I do not have the ion blue projectors and I have tried PIAA Xtreme White bulbs and the ones that came with it. Both gave the same result. Actually both bulbs looked almost the same, Xtreme alittle whiter and not quite as yellow. I just dont know what to do. If I could get them aligned correctly and get the bulbs to look the same it would be great. Currently the driver looks blue and the passenger yellow... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I have posted before and someone said the fuse might be blown, I have checked all fuses and they are ok. Anyone have any ideas to what I can do before I pull them out and send them back????? Im debating on going back to the good ol stock headlights with yellow inserts (non cleared)
Thanks,
Ozzy
Old Apr 17, 2002
TOOLOWCIVIC's Avatar
I'm having the same problem. Can anyone help
Old Apr 17, 2002
Yeah TOOLOWCIVIC Im on the verge of sending them back due to the problems but I do like the look... It will be a shame to return them
Old Apr 18, 2002
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
I have no probs with mine
The blue line is normal. Check out the line pattern on an S2000 or an Audi, they have them too (hence why they change colours when they hit bumps).
Old Apr 18, 2002
Yeah but only the driver side has a noticible line, you cant see it on the passenger side when viewing from the front of the car.......
Old Apr 18, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
sounds like you all need to adjust them! On the back of the projectors are some phillips screws around where the low beam bulb is. What I did was parked my car and aimed it at a flat wall such as a garage door, then turn the lights on at night and slowly adjust these screws on the back of the housing from inside the hood. You probbaly need a shorty phillips screwdriver. If you already tried that, then I don't know what to say... Later...
Old Apr 18, 2002
Well I did this tonight and it made some difference. I aimed the passenger lamp higher than the driver side. Atleast there even now looking at them, the only problem now is that the driver still looks blue at times while the passenger never does. Guess beggars cant be choosers. Oh and I have some PIAA Super Plasmas comming in tomorrow, Ill try them out and post the results.....
Lata
wingsfan19
Oct 1, 2015 03:45 AM
carid
Jun 5, 2015 11:51 PM
Exbauer
Apr 3, 2002 01:04 AM
Masheen
Mar 8, 2002 10:07 PM
Diznavis
Feb 19, 2002 12:41 PM
