01-03 vs 04-05 OEM Tail Lights
Fiberglass Guru
Rep Power: 0 01-03 vs 04-05 OEM Tail Lights
I just got my set of DEPO aftermarket taillights. Physically, they fit great. however the wiring harnesses do not match up. They said that they fit 01-05, I have an 04 and I just want to verify that the harnesses are the same for all 01-05s.
for example: Could you swap a set of 01 Tails into an 05 without modifying any wiring?
If so then I have to contact the company to see if there is a quick fix before I start cutting the harnesses.
Thanks in Advance.
Thanks in Advance.
Rep Power: 0 Re: 01-03 vs 04-05 OEM Tail Lights
Nope you can't. If you look in the DIY section, there's a whole thread about switch the tails and I believe the back up light and the socket is wat needs to be changed....
p.s> if you do a search there's tons of threads about how the lights are different and stuff, nd wat you need to do to make them fit.
shaejb15
04-12-2015 11:38 AM
