Installing Ground Control On my sedan, WHAT ELSE DO I NEED?
Old 03-20-2002
netcbc's Avatar
netcbc is an unknown quantity at this point
Do you guys think i'll need cambers or shocks?
Old 03-20-2002
SuperCivic2k1's Avatar
SuperCivic2k1 is an unknown quantity at this point
yes, you will need new shocks. and chamber kit is good to get if your lowering your car 2.0 or more unless you want your tire to warn up fast like in 2 months so if i were you, i wouldnt install it if your gonna lower it 2.0 or more. get all your stuff ready then do it.
Old 03-20-2002
netcbc's Avatar
i'll probably go 1.75 1.5
do i need any camber or anythnig?
Old 03-20-2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
depends... i am on H&R stage 2 springs... approx 1.3 drop. the alignment guy said i was 1 degree off in the rear... the front... i got camber kit so it fixed all the problems. i presonally recommend camber kit if you are gonna lower your car. some people say a +1 degree on your camber will allow better handling... but since you are gonna drop 1.5 inch or so... you should get it. oh yeah... i was on coilovers prior to the springs..... i hated teh coilovers due to the ride quality compared to springs. when i had coilovers... i didnt have camber kit at the moment... and my front tires were seriously worn down... i had to have the tire shop flip the tires so it will wear out evenly through time. i hope this input helps.
Old 03-21-2002
netcbc's Avatar
ah crude, what kind of coilovers did you have?..... i have ground control eibach ones, i tried to get the best ones hoping these were it
Old 03-21-2002
TOOLOWCIVIC's Avatar
Ground Control are the best ones. You will eventually blow out your shocks and will have to buy new ones.
Go with the Konis it will keep your car from bouncing as much.
my2k1vic
11-29-2001 10:29 PM
1028CiViC
11-27-2001 02:45 PM
1028CiViC
11-24-2001 02:14 PM
duyaknow
11-23-2001 07:28 PM
TOOLOWCIVIC
11-18-2001 10:17 AM
Quick Reply: Installing Ground Control On my sedan, WHAT ELSE DO I NEED?
