Sponsored by:
Sponsored by: CARiD
nitrous kit for the 2001 civic
Old Mar 19, 2002
CIVICINJEN's Avatar
CIVICINJEN is an unknown quantity at this point
ok, now in order for me to get nitrous for my 2001 civic ex coupe this is what i need. all im looking for is a 50 shot
- a wet kit
-a kit that atomizes
-a clutch
new colder plugs
-and a window switch
-and some other stuff.
now my question is does anyone know which kit offers all these things and which kit is safer to use(eg. nos, nx xpress, venom but they only have dry.) so any infomation would be great thanks
Old Mar 19, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
nitrous express is best. get he kit, the bottle opener, the bottle heater, fuel pressure gauge, oil pressure gauge, and run a 50 shot. their bottle heater is the best heater because it heats it so its at a constant pressue unlikes nos where it keep it at 85 degrees no matter what. in a nutshell thats it and its better.
Old Mar 19, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
NX kit is a dry kit... and from what i heard is better nitrous kit to run on our cars, opposed to the wet kits... something about the dry kits apparently is either alot safer to use, or alot more productive. i dont know to much tho, so u better do some research before u actually buy a kit.
Old Mar 19, 2002
MoMatt's Avatar
MoMatt is an unknown quantity at this point
but if I was you, Id order the venom computer, I dont have nitrous on my car, but my friend runs NOS and he has the Venom kit and its really tight. I think the computer is only like 400 or something like that. Its in all the magazines.
Old Mar 19, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
correct me if I'm wrong somebody but I don't believe a dry kit will work on our car due to the returnless fuel system--->dry kits are considered "safer" than wet kits because on a wet kit there is the possibility of fuel leaks (let's say you get an AEM fuel rail, pretty much any type of fuel leak problem will be nonexistent) although wet kits are considered much better because nitrous and fuel are injected in exact amounts to prevent a lean mixture and maximize power to each cylinder. A dry kit however relies on the preset amount of fuel dished out by the stock injectors so each cylinder can get a different amount of nitrous (one cylinder might get more nitrous than the other) but each cylinder will get the same prescribed amount of fuel from the injectors which may potentially lead to a lean mixture and everything goes downhill from there [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
The NX kit boosted the 01 ex from a dyno proven 110 hp and 103 ft. lbs. of torque to a whopping 170 hp and 200+ ft. lbs. of torque (don't quote me on those exact figures but they're pretty close)
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
