Sponsored by:
Sponsored by: CARiD
Magnaflow Exhaust
Old Mar 13, 2002
Blacatoe's Avatar
Blacatoe is an unknown quantity at this point
Magnaflow Exhaust
I just installed my Magnaflow Cat and the smell is wierd, and the sound is too soft! I know the smell will last a while, but will it ever get louder? I didn't want a weed wacker sound, but damn my pipe is silent. I also had to get a buddy to torch & crimp the pipe where it runs past the lower sway bar because it was bent to early so it was knocking when I turned, anyone else?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 13, 2002
Mbow's Avatar
Sound is a little soft probably because of the resonator. Smell will go away shortly. I had problems with my tip hitting the bumper and the u-bolts not sealing the connections. It will get just a little louder as it breaks in. I think if this system was loud, it would be a real ricey sound.
Old Mar 13, 2002
Blacatoe's Avatar
Hey Mbow!? I had problems with the tip hitting my bumper too! Have you fixed the problem, if so how bro? I've just been pulling up on the bumper like crazy![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Mar 13, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
The smell will go away in a while. The sound will definately get louder. Not loud loud, but louder. You will never get a weed wacker sound so don't worry. It will get deeper and more mellow after a couple months. To make it sound even better yet get an intake if you don't have one yet. Hope this helps.
Old Mar 13, 2002
bobbyd's Avatar
To keep the tip from hitting the bumper, don't pull on the bumber, bend the hangers connected to the muffler to get the muffler to drop a tad.
Old Mar 13, 2002
Mbow's Avatar
<< To keep the tip from hitting the bumper, don't pull on the bumber, bend the hangers connected to the muffler to get the muffler to drop a tad. >>
Yes, that is what I did. I layed underneath the car and hit upward on the hangers with a hammer. It did the trick. There doesn't have to be big gap, just along as they aren't touching.
Old Mar 13, 2002
uicmedruss's Avatar
uicmedruss is an unknown quantity at this point
yeah...that sheit they coat the pipes with when they mendrel bend them sure does reek somethin aweful when you start burning it off...don't worry tho, the smell will go away...
oh...and your muffler WILL get a little louder and deeper
Old Mar 14, 2002
Gen7Civ's Avatar
Gen7Civ is an unknown quantity at this point
Yeah, Im having the same problem with the front section rattling and hitting, when turning, when driving over roads that arent perfectly smooth and sometimes even when accelerating normally...have to get that fixed soon cause it sounds like crap! I also might have it welded so I know theres a good seal at each joint. Have noticed that its gotten more loud and deep over the past week, just a little though.
Old Mar 14, 2002
MagnaflowGuy's Avatar
MagnaflowGuy is an unknown quantity at this point
You shouldn't have to weld anything......If your hearing banging or rattling, that's not normal! Either it's not tightened or not hung properly.....Anyone who has a problem, call me at the office 9-5, I'll help you as much as I can over the phone.....
John[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 15, 2002
Gen7Civ's Avatar
Found out why it was hitting the front sway bar...there was no tension on one side of the connection where it first bolts to the cat, which caused it to line up right next to the sway bar instead of where it should be. All fixed now though and much nicer not having to drive like a granny to cut down on those rattles. Sound is better now too because the seal is much tighter too.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
