Sponsored by:
Sponsored by: CARiD
Do Gas Treatment products work?
Old Feb 26, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
Theres a few made by STP and theres a new one made by NOS, hah....... but wondering if these work?
Old Feb 26, 2002
Voiceofid's Avatar
End Bringer
i used it a few weeks, i notice my engine is a little quieter, and just slightly bit more faster off the line, but it could just be a psychological effect
Old Feb 26, 2002
Grey's Avatar
DIY King
Yes. I don't know which STP that is there? I use STP fuel injector/carburator cleaner every other time I fill up. It helps to clean the fuel lines and fuel injectors from deposits that build up and hinder the flow of fuel. The NOS Octane Booster is just that, it increases the octane rating of your fuel. Only use it if you don't have high octane fuel available in your area. Our cars only need 86 octane (typically 87), so there is no need for this product. Even with a turbo, nitrous, or a supercharger you might only need to run as high an octane as is sold at the pump. Although if someone has seriously high compression, or seriously high boost pressure, then upping the octane level of your fuel to prevent detonation is a good thing. Only us as much as you need to to kill detonation though, too much is just a waste.
Old Feb 26, 2002
HondaLuver's Avatar
Its a celebration bitches!
actually it hurts our cars, i forgot what it was but if you look in your manual it will tell you. one of the chemicals in the additives destroys a sensor or something. and what kind of build up do you have on a car with 20,000 miles on it, it is barly broken in.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 27, 2002
thundercats4ever's Avatar
thundercats4ever is an unknown quantity at this point
I heard that they usually don't do anything good. If you get good brand name gas you should be fine.
Old Feb 27, 2002
leadfoot78's Avatar
leadfoot78 is an unknown quantity at this point
Be careful with that stuff. My last car was an Altima. I bought Bosch +4 plugs for it and thought that I should clean the fuel injectors too so I bought a Pennzoil brand injector cleaner and poured it in. It destroyed the plugs totally, I got of the free way and the car started hesitating and making a NASTY [IMG]i/expressions/face-icon-small-puke.gif[/IMG] noise like it was about to brake down. At one time I barely got up a hill. I thought the engine was garbage. I took it to the dealer and they ran a test and said that the plugs are crap. The truth is the cleaner destroyed them cuz i drove on them 2 weeks before and they were awesome gave me very clean starts.
Old Feb 27, 2002
Dave's Avatar
Dave is an unknown quantity at this point
Yeah it's not a good idea to use the fuel injector cleaner too often. I use it about once every 3 oil changes. The rest of the time, I just fill up at Chevron wich contains a small amount of techron to do the job.
Old Feb 27, 2002
netcbc's Avatar
what abotu gas treatment fluid heh? cause you guys keep talking about fuel injector fluid
Old Feb 27, 2002
Doc's Avatar
Doc
Doc is an unknown quantity at this point
Fuel Injectors cannot be cleaned by putting an additive in your fuel system. Fuel Injectors can only be cleaned by removing them from the engine, taken apart then placed in a ultrasonic cleaner. This should only be done by a profesional. The additives that you buy and pour in your gas tank will clean deposits off of your Intake valves and some of the carbon deposit on the top of the piston. It is OK to use cleaners that specify Fuel Injected Safe, these do not contane the chemical that will make your O2 sensor go bad. Hope this helps!
Old Feb 27, 2002
2cute's Avatar
2cute is an unknown quantity at this point
The best thing you can do and it will save you money in the long run is to run your car on 87 octane, which it is designed for, and the about once a month or so run the 92 octane. The 87 octane will leave some deposits but if you run the 92 (burns hotter) once a month that will burn up all the deposits that have developed. That's just my 2 cents though
Old Mar 3, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Chevron Techron and Amsoil's cleaner have worked for me.
Shakzhussain
May 17, 2015 12:03 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Ashley Farr
May 7, 2015 05:01 PM
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
