Sponsored by:
Sponsored by: CARiD
Another Short Shift Post
Old Feb 26, 2002
ivonesh's Avatar
ivonesh is an unknown quantity at this point
Here is my question that has not been answered in any search. Is the Revo Short Shifter unique in that it reduces throw and height? Or is it just the reduced height that causes the illusion of tighter shifts? If it is just the height then a DIY is the way to go, if not I will buy the revo. Hopefully someone can answer?
Old Feb 26, 2002
eProdigy's Avatar
eProdigy is an unknown quantity at this point
Im not sure about that, i have the solo short throw and it does nothing for the actual hieght of my shifter, just shortens the distance. that bad boy is sweet though
Old Feb 26, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
actually the answer is in just about every post... you just didnt read enough....anyway it is actually shorter about 1 and a half iches shorter to be exact
Old Feb 26, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
carboncivic - you did not answer his question, he wants to know if the revo is actually designed to reduce the throw (different connection points for the cables, etc.) or is it the fact that it is just shorter that gives the feel and effect of shorter throws?
Old Feb 26, 2002
my bad..... it does create shorter throws because of the shorter height.... anything else?
Old Feb 26, 2002
mohawkboom's Avatar
It is just shorter in height.. uses exact same mounting setup for the OEM Shifter.. Cut the shifter.. get an Solo or Neuspeed SS adapter..
Cheers
Mohawk
Old Feb 26, 2002
ivonesh's Avatar
Thanks Mo
Old Feb 26, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
I have the revo and I love it. I have beat many cars simply because I have the ability to shift faster. While the shifter is about an inch shorter, it does reduce the throw by a very noticable amount. It is the exact same setup, but the difference comes in the lengh of the shifter, and I also noticed that the spot that the cables hook up to is a bit different also. If you get it, I promise you won't be dissappointed.
Old Feb 26, 2002
netranger's Avatar
netranger is an unknown quantity at this point
It changes the mounting points exactly like the solo does, and it is shorter in height because it is a real shifter, not an adapter
Old Feb 26, 2002
nongv's Avatar
nongv is an unknown quantity at this point
anybody ever tried the revo with the adapter
Old Feb 26, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i'm gonna try it if i ever get my hands on an adaptor. gotta find someone that will let me borrow one. i'm gettin my revo installed this weekend
