Sponsored by:
Sponsored by: CARiD
NHBP spray paint
Old Sep 8, 2005
bkidnon's Avatar
bkidnon is an unknown quantity at this point
NHBP spray paint
Where can I buy?
Old Sep 8, 2005
blouisgod's Avatar
Life Begins > 6800rpms
paintscratch.com
i ordered some last week so it should be here soon. ill post up some pics on how it works.
Old Sep 8, 2005
bkidnon's Avatar
Thanks.I'm trying to paint my headlight housing to match the car color.Don't really know what to do tho..any help would be great.
Old Sep 8, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
Thats exactly how i did mine. Check with local paint suppliers. Here in Oklahoma there is a shop that will put it in a can, costs like 13 bucks for one can and the paint. Came out perfect. The only thing is make sure that you keep the nozzle clean and shake it like crazy cause the metal flakes and clog it easily and if you dont shake it enough, the flake wont be even. If your using automotive paint though, it will look dull if you dont put a clear on it. I just put a couple coats of automotive clear coat on it and it looks sweet. Make sure the clear you buy is intended for automotive paint though, not all of them will work correctly. You will also need a plastic primer, i used SEM Flexible surface primer, paint, and Ultra enamel clear coat.
Old Sep 8, 2005
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
^^ Beat me to it! There should be some automotive paint places near you and they can get the paint and have it put in spray cans for you. I have had it done before and it worked perfectly!
Old Sep 8, 2005
bkidnon's Avatar
So what do you do first? Paint it with plastic primer, paint , then clear coat? Does it have to be hight temp primer?I don't need to wet sand it right?
Old Sep 8, 2005
I lightly sanded with some 220 grit paper, 2 light coats of primer, then light coats of paint (space each coat about 15-20 minutes apart, this isnt just spray paint and it needs to cure inbetween coats or else it wont dry) then i waited about an hour before putting a clear on it. Wet sanding isnt needed and no you dont need a high temp primer. Just regular automotive products will do. Try to buy it all from one place, and make sure they are for automotive paints.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
