Sponsored by:
Sponsored by: CARiD
lowering
Old Jan 23, 2002
Lianjie's Avatar
Lianjie is an unknown quantity at this point
lowering
i currently have 17 inch rims with 205/40/17 tires.. whats the best way to lower my car, keeping it with a good ride, for a low price??? [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 23, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Eibach spring or Ground control
Old Jan 23, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
Eibach
Pro-Kit : 1-1.5" Drop (All the way)
Sporline: 1.5-2.0" Drop (All the way)
Old Jan 24, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
Pro Kit is the way to go!!
Old Jan 24, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
eibach ground control can adjust the height but the price is high..
Old Jan 24, 2002
mohawkboom's Avatar
<< eibach ground control can adjust the height but the price is high.. >>
Eibach and ground controll are 2 seperate companies.. No such a thing as an Eibach ground controll.. quit post whoring dude...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
But Neuspeed sport springs
or Eibach Pro-kit would be your best solution.
The EIbach pro-kit will drop you 1" all around
Neuspeed will drop you 1.4" front 1.2" rear..
Old Jan 24, 2002
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
I believe that Ground Control uses custom made springs by Eibach so they are related. Check the website for yourself at http://www.ground-control.com
Old Jan 24, 2002
slam2k1civic's Avatar
slam2k1civic is an unknown quantity at this point
for the price get dropzone $130.00 click here
Old Jan 24, 2002
Lianjie's Avatar
wow, thanks for the quick replies, so far i think im leaning toward ground control right now.. thanks for the feedback though [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 24, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
Two - Words.......PRO KIT
Old Jan 24, 2002
SneakerPimp's Avatar
SneakerPimp is an unknown quantity at this point
If i was you I would get a good set of springs and a full set of koni yellows. You can't go wrong with a full suspension rebuild.
Old Jan 24, 2002
1028CiViC's Avatar
mohawkboom: ground control uses eibach spring and i am not post whoring ...
if u don't know check it .
Old Jan 30, 2002
Lianjie's Avatar
if i get the eibach pro kit, is that all i need to lower it successfully?? or do i need to buy something else with that..
help a newb out here [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Thanks
Old Jan 30, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
<< If i was you I would get a good set of springs and a full set of koni yellows. You can't go wrong with a full suspension rebuild. >>
that's what I am going to be getting. Eibach Pro Kit and I am also adding on the Ingall's camber kit to that.
Old Jan 30, 2002
fogbow's Avatar
fogbow is an unknown quantity at this point
<< if i get the eibach pro kit, is that all i need to lower it successfully?? or do i need to buy something else with that..
Thanks
I'm new at this but that's all you need to drop yuor car except for the tools and stuff to install them. Places like Tire Rack suggest you get a alignment kit with Eibach springs. One problem you may run into when lowering your car is that your shocks will go out after time. And what I hear is that you shouldn't lower your car any more then 2" or you can blown out your shocks out quick. The only aftermarket shocks out at the moment for our car is Koni yellows which are adjustable and everything but have a pretty price tag. It will run you like 550-600 for them.
I want to lower my ride with a Pro-kit, Sportline or Ground Control but I don't want to mess my shock/struts up so I think I'm going to wait til I can get some Koni's or something and do it all at once. I'm hoping that they will be some other shocks released by then so I can save a little money.
Old Jan 30, 2002
Lianjie's Avatar
ok, thanks
Old Oct 7, 2003
fennel123's Avatar
fennel123 is an unknown quantity at this point
huge huge noob here. i have those multi spoke 16 in rims which look pretty nice. i bought neuspeed race springs, front and back koni yellow shocks, and a front and back camber kit. anything else i need? anything on my last i should return or not have gotten? thanx for the help. also, anyone have those neuspeed race springs? your car look agressive now?
Old Oct 7, 2003
civicvtec1ps's Avatar
Search and Learn
thats all you need. since you even bought aftermarket insert shocks. you are set to lower 4x4
Old Oct 7, 2003
if you want coilovers, you can go either ground control (like previously mentioned) or you can go with a full coilover strut, like Tein basic/super street dampers or K&W (i think thats the company) coilover struts... kinda pricey (around the $1k+ range) but more worth it IMO...
Old Oct 7, 2003
BoSS's Avatar
BoSS is an unknown quantity at this point
is the Prokit springs good?
I'm thinking about getting these but I want to hear from someone with first hand experience about them....I have a questions?
Are they stiff?
like way stiffer then OEM, or like juss a touch?
thanks
Old Oct 7, 2003
tripledoublegs's Avatar
Euro-Spec
Eibach Pro-kit.
But if you have the money, go with Tein. Its around 800, but you get some serious s**t
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
my setup:
205/40/17 tires
17'' Wheels
Goldline Springs..
I Love My Setup!
1 finger gap all the way around!
Old Oct 7, 2003
whas the drop with the goldlines?
Old Oct 7, 2003
Samari's Avatar
Tein S Tech
Old Oct 7, 2003
JayFReaZy's Avatar
Just wondering, when you got the pro-kit, did yall have to change ur shocks and get a camber kit?
Old Oct 7, 2003
Search and Learn
no do not NEED to get new shocks. and you wont neeed camber kit with prokit drop.
Old Oct 7, 2003
JayFReaZy's Avatar
When would you need new shocks and a camber kit then? Prokit fits the sedan?
Old Oct 7, 2003
02ciVike's Avatar
02ciVike is an unknown quantity at this point
H&R Sport Spring are great too. They are a healthy drop in between a substantial drop and and a small drop. They will lower your car 1.3", they ride decently, and get rid of most of that wheel gap. Check out my ride. I have had them on for 4 months and my shocks are still in great shape.
Old Oct 7, 2003
02ciVike's Avatar
I believe that H&Rs are for the coupe only so if you have a sedan you are SOL. Correct me if I am wrong.
Old Oct 7, 2003
Search and Learn
http://www.7thgencivic.com/modules.p...Suspension+FAQ
read faq people
