Sponsored by:
Sponsored by: CARiD
Best Springs
Old Jan 19, 2002
mohawkboom's Avatar
Best Springs
Which Springs have the Stiffest firmest ride and low drop.. Neuspeed Race?.. Eibach Sportlines.. My System weighs damn near too much for lowering springs to porperly support without getting too low. And I don't want to give up performance either... Any ideas/help
Mohawk
Old Jan 19, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Well, I've got GC's with a set of Koni's. And with my Q logic box, both IDQ subs, and all the custom MDF I've put in my trunk(mounts outside the Qlogic box), plus the amps and cap, I'd say my system weighs in at well over 200 lbs. And I'm not finished yet. But, I've got my GC's set pretty low currently ,no fender gap in any corner, and it rides great.
Old Jan 19, 2002
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
Consider the Ground Controls. Adjustable height to compensate for your system and eibach springs for performance.
Old Jan 19, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
ive got my 2 12"s in a box with 2 amps on it in the trunk and im ridin on my neuspeed race springs just fine
Old Jan 19, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
ground control or eibach..or h&r good stuff..
Old Jan 19, 2002
mohawkboom's Avatar
Cool.. problem is though I live in Montreal where the salt the roads to hell in the winter.. so Goilovers can't be done.. the Aluminum frames oxidize then the threds lock into place.. eventually decompose and the threads break.. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]. I'm Hoping Eibach Sportlines or Neuspeed Race spring can hold up.. and 0100010 My trunk install weighs well over 450lbs. with...just the enclosure weighs 235 with the subs in it..
Cheers
Mohawk
Old Jan 19, 2002
0100010's Avatar
Ouch, over 450lbs? So with you in the car, then you've only got room for about another 150-200lbs then(800lb carry limit on a civic). I guess you only ever take yourself, or maybe one other person?
Let me see if I was correct on my weight estimation.
Sub Box - 80lbs
Subs - 30lbs each(60lbs total)
Amps - 30lbs(1 zapco and 1 RF)
MDF(3- 2'X4' sheets) - 80 lbs
cap - 2lbs?
So yeah, right around 200+ pounds for mine. Not too bad. I can't imagine cruising with a 450lb+ system. But, its all good, I'm sure your system rocks.
As far as the no coil over thing, then as long as you go with Eibach springs, you should be good to go. Pro-Kit or Sportlines. Eibach is the best.
Old Jan 19, 2002
1028CiViC's Avatar
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
