Sponsored by:
Sponsored by: CARiD
Reverse Lights, Not 7440
Old Dec 22, 2001
Dr5D's Avatar
I was informed that the back up lights were 7440s so I went and bought some, but they dont fit! are they supposed to be 7443s? somebody help!
Old Dec 22, 2001
XenonCivic's Avatar
XenonCivic is an unknown quantity at this point
they are the same as the blinkers
Old Dec 22, 2001
Dr5D's Avatar
it says that the front turn signals are 7443, is that what you mean? it says that the rear turn signal is a 7440 and the taillight is 7443 and the rear sidemarker is also 7443 but the reverse lights are not 7440! and now that I think about it the rear sidemarker is not 7443 I dont think cause i got a 168/194 in there, it didnt seem correct, but it still fit.
[IMG]i/expressions/face-icon-small-puke.gif[/IMG]
EDIT :
I am using the Sylvania web site for refrence.
Old Dec 22, 2001
SWEETRIDE's Avatar
SWEETRIDE is an unknown quantity at this point
They are 7443's, Just go to the DIY section at the top of the page and there is a light bulb chart for the civic located there.
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 22, 2001
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
who told you they were 7440?
Old Dec 22, 2001
IonRays's Avatar
IonRays is an unknown quantity at this point
yea i thought they were 7440 too...from that old post i readed
i was goin to get 7440 too...wooohoo close thanx
Old Dec 22, 2001
Dr5D's Avatar
Sylvania is the one who has been wrong more than once, most of the stuff is right, but be sure you double check before using their info
Old Dec 22, 2001
Damian2k1's Avatar
Damian2k1 is an unknown quantity at this point
I think the difference between the 7443 and the 7440 is that the 7443 has two filaments whereas the 7440 only has one. Therefore the front signal light, since it requires 2 filaments (lower wattage filament used as driving lights, higher wattage filament used as turn signal), would be a 7443. The rear brake-lights also require two filaments (lower wattage for when your lights are on, higher wattage for when you apply the brakes) and are 7443. The rear signal light, however, only require one filament, and, to the best of my knowledge, contrary to the DIY bulb chart, would be 7440. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 22, 2001
joe's Avatar
joe
joe is an unknown quantity at this point
the part number for the reverse lights is 921. take a really close at the original bulb the part number should be there on the bulb.
Poopies
Apr 20, 2017 11:36 PM
Blazz
Jun 4, 2015 01:04 AM
Richkid23
Apr 19, 2015 12:53 PM
mwwhonda
Nov 30, 2001 08:44 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
