Belt Tension Gauge, Where to Get?
do they actually make these kind of gauges? i never knew that. What's it for anyway, which belt are you worried about?
Originally Posted by SIinthesky
I've changed so many belts in my days and have never used a belt tension gauge. I guess my gauge is my hands.
Although this is an older thread, because I recently spent quite some time searching for an affordable belt tension gauge, I thought it would be courteous to share what I found.
The Honda Civic maintenance manual gives a specific belt tension for AC, alternator & power steering belts. Improper belt tension does cause premature bearing wear, and belt wear over time, whether too loose or too tight.
If your a tenacious and patient mechanic this simple belt tension gauge can give you an accurate and consistent measurement. It's $18 and available from NAPA. Could be available from other vendors also.
cgavin1
Jul 7, 2015 07:10 AM
