SPARKPLUG: center electrode sizes
Originally Posted by FALKEN
what differences would there be between a plug with a .4mm and one with a .7mm (both are iridium)
So in other word the .4mm will require less voltage to operate than the .7mm.
Civicforums Junkie
Originally Posted by EManEX
The required voltage will increase as the electrode diameter increases...in other words, the .4mm will require less voltage to operate than the .7mm
Civicforums Junkie
according to www.sparkplugs.com
Denso is claimed to have .4mm electrode size
NGK is claimed to have .7mm electrode size
if the Denso created less voltage to perform, would it create less spark also??
No. The sparkplug will require less voltage to create the same spark in a given gap.
That's true. Running regular ngk vs iridium I saw a huge voltage requirement difference. The copper plugs dropped system voltage by almost .5V! Iridium is the way to go for lightly modded cars.
Civicforums Junkie
i just got the NGK Iridiums (6441) today...4 for $25.00!!
im running the Bosch Platinum +4s right now with 4900mi on them...
im going to swap them out and see if theres a difference
solarpunk70
Apr 12, 2016 11:43 AM
68camerors
Sep 24, 2015 06:18 PM
Touge
Sep 22, 2015 11:55 PM
Touge
Sep 18, 2015 12:13 AM
