Sponsored by:
Sponsored by: CARiD
Altezza Grille, RS come off? ASAP
Old Feb 3, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Hey guys,
I am about to order an Altezza Grille from Dezod. HE said it has the RS symbol on it which I do not want, but he said it is removeable and is optional he believes. I just want a plain altezza grill though and Rob at Robear Racing said he cant seem to locate any.
So does the RS just come off and make it look like a normal altezza grille?
Thanks
Old Feb 3, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
yea the Rs will come out but NOTE u will still see the RS on the Grill its just like a Oem honda grill if you take of the H you will see the backround of it same the with the RS grill if you take out the RS you will still see the Backround of it.
Old Feb 3, 2004
FALKEN's Avatar
Civicforums Junkie
the RS grill is not the same as the ALTEZZA grill...theyre different
Old Feb 3, 2004
RedDragon333's Avatar
you can remove it easily but you will have a spot where the RS should be. So it wont look like an altezza grill.
Old Feb 3, 2004
nme3's Avatar
JDM wannabe
yah the altezza grill and rs grill are different. if its the altezza grill with the rs emblem then it should come off easily with no outline behind t, but if its the rs grill with the emblem then it will have the outline.
Old Feb 3, 2004
civicvtec1ps's Avatar
Search and Learn
Rs grill and Altezza grill is totally different shape.
When you take out "RS" sticker. You will still see "RS" shape on the grill.
Just get Altezza grill off ebay.
Old Feb 3, 2004
azure's Avatar
Yup, like everyone else said, the RS and Altezza grills are different. So Rob doesn't have anymore Altezza grills in stock? Try ebay. Here you go: http://search.ebaymotors.com/search/...ch=&category0=
Old Feb 3, 2004
azure's Avatar
Whoa. I just noticed Rob used my Civic as an example for the Altezza grill.
http://www.robearracing.com/pd_honda_civic_01.cfm
Old Feb 3, 2004
7thGenerasianCivic's Avatar
No... altezza grill is an altezza grill there is no "RS" place to stick the sticker on.
Old Feb 3, 2004
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
The RS grill doesn't come with the RS already stuck on, it's a flimsy red vinyl sticker that they leave to you to put on yourself. So if you don't want it, you don't have to put it on. But as has already been said, the bare spot for the sticker, the 'foundation' if you will, will still be there.
Incidentally, if you decide later on that you do want the RS badge on there, DON'T use the stickers that come with it. They suck *** & fade after a few weeks so all you're left with is some faggy looking pink letters. Instead, drop a few bucks and get the plastic badge from Tornactive. It's a much nicer solid plastic piece that I've had on my grill for a year, and so far it has little more than a few small scratches on it.
'Course, if you find an altezza grill and go with that instead, then everything I just said will be completely useless to you ...
*sigh*
Edit: For clarification purposes
Old Feb 3, 2004
gotti's Avatar
Dude, just get it from ebay. Very cheap, and they have the regular altezza grill.
Old Feb 3, 2004
sCoTtEh's Avatar
sCoTtEh is an unknown quantity at this point
its not the same, just get one off ebay
Old Feb 3, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Haha. Well I bought it BUT I was told by Dezod (who spoke directly from the manufcaturer) that the RS is optional and i had the impression if you dont put it on then its just an altezza grille.
well it looks like i have an altezza grille. oh well.
Old Feb 3, 2004
XxSoVeReiGNxX's Avatar
rs grill has honeycomb mesh
Altezza grill has large diamond mesh (too bad the mesh wasn't thinner and the diamonds were smaller)
here's my altezza grill with painted lip:
don't forget to order a sedan radiator cover to replace the coupe radiator cover (see above pic). Unless you don't mind leaves and other **** getting through the gap and building up inside the bumper Order it at www.hondaautomotiveparts.com (http://www.hondaautomotiveparts.com/...5=FRONT+GRILLE)
Part #2. You all the other screws you will already have.
Old Feb 3, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
sedan radiator cover? i ordered one for a 2002 coupe...
Old Feb 3, 2004
cryption's Avatar
2003 Nissan Frontier
i used my stock radiator cover ... should i change it?
PM me plz!
Old Feb 3, 2004
yes yes all altezza and rs grills will fit both coupes and sedans. But check out the difference in radiator covers:
radiator cover comes with sedan:
radiator cover comes with coupe:
That H emblem imprint is still there on the coupe covers. Similarly, on the rs grill, the RS emblem imprint will still be on the grill even after you remove the RS sticker
Old Feb 3, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
should i worry about it? dezod didnt say anything...can my shop just make it work?
Old Feb 3, 2004
No radiator cover (because coupe cover won't fit rs or altezza grills)
courtesy littleblack01
Radiator cover
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
rnaodm
Sep 21, 2015 12:42 PM
