Sponsored by:
Sponsored by: CARiD
black trim/bezel question
Old Feb 1, 2004
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
Ok guys I just finished installing my aluminum guage bezel... but, after I put the black trim back on I dropped the 2 screws that screw on the top both of them It fell somehwere inside the steering wheel, will that be a problem? I'd probably just have to find replacement screws?!
Thanks,
Ken
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
you could take off the steering column cover and look...that space back there is pretty empty, also try taking off the fuse cover panel below the steering wheel, they may be chilling in there. But that shouldnt' be a problem i dont think
Old Feb 1, 2004
putang inamo!!!
How do I remove the steering wheel column?
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
not remove the column...just the plastic trim around the column...i'll work on a link in the next few minutes
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
here: http://handaaccessories.com/civic/CIVIC01SECURITY.pdf
^those are instructions on how to install an alarm system, but you have to remove the panel I'm talking about, so do steps 3-5 on there and you should be good.
Old Feb 1, 2004
jeepers2xxx's Avatar
jeepers2xxx is an unknown quantity at this point
there is only a couple of screws on the underside its not that hard
Old Feb 1, 2004
putang inamo!!!
thanks guys, what about the little clips? i just re-installed the trim w/out the clips. didn't seem like i needed them...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
viper775
Dec 9, 2001 10:52 PM
BeefMan
Nov 25, 2001 10:38 PM
