Sponsored by:
Sponsored by: CARiD
short shifters (which do u prefer)
Old Jan 11, 2004
ninerfan17's Avatar
ninerfan17 is an unknown quantity at this point
what kind of short shifters do u guys prefer. is it worth it!!
Old Jan 11, 2004
Zzyzx's Avatar
Autocross Junky
Revo SS is the best, it replaces the whole assembly rather then just changing the mounting point of 1 of the cables....
Old Jan 11, 2004
Mr.Modify's Avatar
definitely Revo
Old Jan 11, 2004
Drnknmnky13's Avatar
except the revo has an issue with play. The plastic seems to get chewed up pretty bad. Although it could just be mine. I have to adjust it now and then to get the play out. I'm considering buying a new one and putting a little peice of metal in there.
Old Jan 11, 2004
I'm talking about where the tension spring hits the plastic stop.
Old Jan 11, 2004
xgodxicex's Avatar
xgodxicex is an unknown quantity at this point
wow i havn't herd of that problem before, is anyone else having that problem? i was gunna get the revo
Old Jan 11, 2004
pheaton's Avatar
A descendant of 2k1civic.com
I have the REVO. . I fixed the play and bought CapYoda and Greys upgrade. . Huge huge improvement. .
The play is easy to fix. . If you are gonna get the REVO, just get it and PM me when you get it in the mail. I definately recommend CapYoda's bushings at the least to help with some of the play, I can explain how to fix the rest too if you want.
Old Jan 11, 2004
Kung's Avatar
Kung is an unknown quantity at this point
I have the Revo SS. I have both CapYoda's kit and Grey's kit. I dont know how it feels without these two because I installed it all at once. There is no play in my shifter. It feels strong, but make sure you put lots and lots and lots of that silicone lube they give you on ALL the moving parts.
If it moves, lube it up. Put gobs of it everywhere. Get it all over your hands and dont be afraid to get in there with it. The more the better and smoother the shift.
Old Jan 11, 2004
I have caps and Greys kit...both rock...they do nothing for the side to side play though Greys kit helps with front to back. The side to side is due to the metal eating the plastic on the stop. I had a thread a while back showing where I had to file to fix it...but it just keeps getting worse. Here Is the link to my thread with pics and an explanation.
Old Jan 11, 2004
l00pb4k's Avatar
But it's a Dry Heat
l00pb4k is an unknown quantity at this point
Revo...I don't have any of the other kits and mine works just fine. Don't notice any play.
Old Jan 11, 2004
rscivic's Avatar
rscivic is an unknown quantity at this point
Yeah I am curious too about the ss too- Revo seems to make a good product-
anyone know anything about the Neuspeed? I saw that it is out for the 7th gen but I don't think that anyone has it.....
Old Jan 11, 2004
CapYoda's Avatar
Escaped Convict
I had the neuspeed adapter and it works okay. u wont have side to side play since its an adapter on the stock shifter. it gets the throw shorter and its stiffer. but it retains the stock height so u wont notice that much after a few days.
most short shifter u get use to though.. when I first installed the obx (revo replica) I was like wow! its short! its like a videogame joystick! then a few days later.. eh? stiff? short? I duno.
but once u go back to stock u're like holy crap this is long.
the side to side play has to deal with the plastic retaining the spring... the stock has a stronger spring and the plastic area doesn't get soft as easily.
also another point that brings about the side to side play is the ball joint on the bottom connecting the side to side motion.. hard to explain, but it doesn't fit the housing completely.. hence the play.
Old Jan 11, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
im not a short shifter fan but i would say revo or nuespeed all day long
Old Jan 11, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
damnit i just ordered the revo thurs from rob, but now im having second thoughts. ive never heard anything bad about revo, thats why i got it. did i make a bad decision?
Old Jan 11, 2004
CapYoda's Avatar
Escaped Convict
I wouldn't think so. why do you think u made a bad decision?
I'm saying after awhile u'll get use to the short shifter. u have to. I mean u drive it everyday you'll be used to the fact that its short.
not saying anything bad about it. this is something any kind of modification will do. i mean at first you'll be thrill and all, but after awhile u'll get use to it. like most things in life. boring! heh.
Old Jan 11, 2004
INCivic's Avatar
no not that aspect of it, i mean the play aspect of it. i never heard anything about that before i got it.
Old Jan 11, 2004
CapYoda's Avatar
Escaped Convict
ooh. well that can't be helped. heh.
its not a big deal anyway. u wont notice it much. doesn't bother me.
i mean i dont hold my shifter and wiggle it all the time. *shrug*
u should still like the differences in shifting.. some people do. *shrug*
the only reason I went short cuz of the shift ****, it looks weird on the long stock shift stick.
Old Jan 11, 2004
JCiv03's Avatar
Drnknmnky13, was the plastic tearing away at the point where you filed it down? or the part above it? or both? i'm just wondering becuase i just wondering because i just filed my down as well, but dont want to have the same problem.
Old Jan 11, 2004
INCivic's Avatar
thats true. i wont worry abou it.
Old Jan 11, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Get the Revo SS, never have had any problems yet.
Old Jan 11, 2004
Polamnus's Avatar
Polamnus is an unknown quantity at this point
Get the Revo SS kit, it's totally worth it. Get Grey's and Yoda's upgrade kits while you're at it, they do make a difference. I've only had it on for about a month, and I'm used to it, but I still like it. I'm soon adding a 440g heavy Skunk2 shifter ****, hoping it compliments the feel. No complaints, it has maybe a centimeter of horizontal wiggle, and no vertical. Not enough to be noticable, and a big improvement over stock.
I'm happy with it, and would recommend it to anyone.
Best to all,
Pol
Old Jan 11, 2004
tsabimage's Avatar
tsabimage is an unknown quantity at this point
revos
Old Jan 18, 2004
perry's Avatar
perry is an unknown quantity at this point
yeah, i hear everyone complaining about the play...
is it worse than stock?
the play i have in my 03 EX is insane.
I can wiggle the shifter inside first gear more than my friends shifter moves from 1st to 2nd in his crx.
if i get the revo kit, will the play get worse?
Old Jan 18, 2004
modoman's Avatar
just get the bushings for it and no problemo
Old Jan 19, 2004
Polamnus's Avatar
I don't think very many people at all have been complaining about the play in the Revo. Like I said in my previous post, it's a VAST improvement over stock. If you add Grey's kit to it($6 IIRC), and the Aluminum bushings from Capyoda(if he's still out of stock, go to Kumosport, more expensive for the same thing though), you'll be just fine.
Grey's kit removes all of the vertical play. I still have about a single cm of horizontal play, but that's negligable, IMO, and I never personally notice it.
The aluminum bushings don't do anything to directly help the play, but they do shore the whole thing up very nicely and gives it a very solid feel. The bushings just give a solid mating of the shifter to the car's frame instead of the rubber bushings that it mounts through from the factory.
It was recommended to me by another member to top it all off with a Skunk2 shift ****. Nothing special about the brand name, but they're the only ones I'm aware of that make sucha heavy shift ****, 440grams. It all goes together to really enhance the driving experience, IMO, and would not hessitate to recommend it to anyone.
Best to all,
Pol
Old Feb 2, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Sorry, there is 1 term I dont understand, what is ment by "play"?
Old Feb 2, 2004
newshus's Avatar
newshus is an unknown quantity at this point
Just installed my revo this weekend and I don't have any play.
Old Feb 2, 2004
I didn't either at first. Give it some time. Take it apart now and superglue a piece of rubber band or metal or something in where the spring stop is. You'll be thankfull later.
Actually..you might not be thankful later...cause you'll never get the play in the first place.
Old Feb 2, 2004
acidbaby's Avatar
The Beez Kneez
just get the grey and capyoda upgrade! they both work great.
"play" would be unneeded motion in the shifter. if you can get rid of it you will have faster more precise shifts!
i have the revo ss, alluminum bushings, and greys upgrade. very big difference in fast shifts. but with your slower more daily shifts you acctually have to push it a little harder than stock to get it into gear.
there is like 20 threads on this subject maybe try the search button next time
Old Feb 2, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I also have the Revo with CapYoda's and Grey's upgrades. I love it. I don't get that much play at all. A little more than when I first installed, but nothing to care about. It's all pretty solid. Even if my car was totally stock, I'd still change to the short shifter. It's a lot more comfortable, as our shifters are annoyingly too long IMO.
