Sponsored by:
Sponsored by: CARiD
Pivot Shift Light (F1 sequential lightup)
Old Oct 14, 2003
CarbonFly's Avatar
Does anyone know about the Pivot shift lights? It says that you only have to plug it into your cig outlet and it works. There is no wiring needed. I dunno how it reads your rpms if it isn't hooked up to the tach of your car.
http://www.the-pivot.co.jp/new-pages...CTS/SSL_E.html
The one I want is the SSL-PRO: 3-Step System Shift Lamp
■Used in F-1 and GT races, this shiftlamp comes complete with a warning lamp function.
■Lights are lit in order at RPMs below shiftpoint; blinking rapidly upon reaching shiftpoint.
■Light up color=Red
■The SSL-Pro does not require any wiring into the tach circuit, it plugs simply into the lighter or can be hard wired to the power supply.
Old Oct 14, 2003
skipbarber's Avatar
i find that hard to believe..the cig. lighter only gives 12v and ground. Im guessing that the device itself has other means of detection..?
Old Oct 14, 2003
CarbonFly's Avatar
Yea, I wasn't sure what to think either, but they use them in race cars. True JDM fashion.....hehehe
Old Oct 14, 2003
civicvtec1ps's Avatar
Search and Learn
i been reading reviews on clubrsx and other car forums. shift light does work. its kinda like g tech , that plugs into cig plug . im planning to get it eventually. or autometer pen size shift light
Old Oct 14, 2003
one for the kid's Avatar
one for the kid is an unknown quantity at this point
what does is it supposed to do? just tell you when to shift? what are the three lights for?
btw, they have a usa site where it lists the prices in dollars and also gives a little more info on their products: http://www.pivotusa.com/cgi-local/So...exe/?E+scstore
Old Oct 14, 2003
ElwooD's Avatar
ElwooD is an unknown quantity at this point
here is the instructions
From what it looks like there is an extra wire for the RPM signal, which is optional.
The pdf is a 1mb so dial up may be slow.
http://www.pivotusa.com/installationman/pivssl_p.PDF
My friend has a Pivot in his 68 mustang (PIVRSL) and it sweet but it is hard wired to his coil.
Old Oct 14, 2003
i'm still confused on how it works..
Old Oct 14, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
it probably reads the RPM signal somehow. i used to work at an auto garage and i would take cars to inspection all the time.
sometimes the inspection guy would clamp some kind of wire around the spark plug wire and it would read the RPMS for the emission testing.
for cars like our civics and other cars that either dont have spark plug wires or the wires are too thin, he puts this "infinity" shaped antenna thingy on the windshield and it reads the RPM's to display on the computer screen, and its pretty damn accurate.
im guessing thats how that tach thingy works.
Old Oct 14, 2003
cdmx's Avatar
think of it as a drag light turning green, they all flash in a sequence then they all flash at once when your supposed to shift
Old Oct 14, 2003
CarbonFly's Avatar
Re: here is the instructions
Thanks for that post. What they say is that you should try it on the autodetection system first. Then if it doesn't work, just hardwire in the RPM signal wire and everything will work.
This is really cool. I'm gonna get it.
Old Oct 14, 2003
cdmx's Avatar
sweet fly and you wouldn't have never found that if it wasn't for me. Your welcome!
Old Oct 14, 2003
skipbarber's Avatar
if you guys dont want to run a wire for tach through the firewall and under the hood, i can find which one it is in the gauge cluster when i put in my reverse glow gagues this week. although im sure if you search someone has already found it.
Old Oct 14, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
maybe the power to the cig lighter fluctuates a little bit on every spark plug ignition; you know, the battery doesn't give as much juice; maybe it senses that?
Old Oct 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
y would u do that? the rpm signal is right behind the glove box..
Old Oct 15, 2003
EviLMyStS's Avatar
All show!!!
cool **** yo!!!
Old Oct 15, 2003
CarbonFly's Avatar
LOL
Old Oct 15, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
It works the same way the GTech and some Turbo/NA Timers work. The GTech is hooked up to a 12V source (Cig Lighter), and the Timer is hooked up to a 12V source (ignition wires). When you put a load on the engine there is a small fluctuation. On a turbo timer, if you have it set to auto, the harder you drive, the faster the timer counts up. Same idea with the GTech, same idea with this.
And since this works the same as the GTech and depends on the fluctuation in voltage... it's probably not going to be entirely accurate all the time unless you have the same load on the electrical system all the time. An example would be a slight change if you have the headlights on, as opposed to having them off.
Old Oct 15, 2003
CarbonFly's Avatar
I agree, but they provide a wire for me to hardwire it into the RPM signal so I won't have to worry about the fluctuation. It seems they just wanted to make it so that any ol' joe could do it, but I'm glad that they give those of us who want accurate readings the ability to make it totally functional.
Old Oct 15, 2003
Boosted2k2's Avatar
I didn't know about the RPM wire. Sounds good to me then.
Old Oct 15, 2003
CarbonFly's Avatar
Yep, Check it out in the link below.........
Old Oct 15, 2003
JLODVO's Avatar
JLODVO is an unknown quantity at this point
i have one similar it just plugs to the cig. its from axas its nice but the thing is u have to set up the sensitivity the way u wud need it, like it u set it up without using the head lamps and use it with the head lamps on it wud be a little bit off u need to set it up again with the lights on
sdaidoji
21
May 5, 2011 05:03 PM
Hwoody77
Engine Swaps
25
May 18, 2007 04:52 PM
dezod
Sep 12, 2005 09:16 PM
ASIANPRIDE
Feb 11, 2004 08:35 AM
SlvrLx26
Feb 1, 2004 12:41 PM
