Sponsored by:
Sponsored by: CARiD
engine ground wire
Old Sep 25, 2003
realitycheck's Avatar
realitycheck is an unknown quantity at this point
engine ground wire
when i went to nopi i saw that someone had the wire that is by the radiator and runs from the top of that frame work and to the engine and had replaced from that naked grey wire to like a 4 guage red speaker wire does that do anything help in anyway or not
Old Sep 25, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
a lot of people here recommend grounding kits. Several wires which ground your engine and electrical system better. Don't know about the one you're talking about, but the grounding system on Hondas is pretty bad.
Old Sep 25, 2003
Search for DIY grounding kit. There is a whole post about this.
Old Sep 25, 2003
yeah i already read the one diy and i thought the way that looked was horrible with those wires running all over the place im talking about the small silver wire that has no cover on it that run next to the radiator hose its about 1 ft long
Old Sep 25, 2003
I replaced that once but it maybe decreased performance. Probably it won't do anything. The whole kit will help. As far as having wires all over, most of mine are hidden, and the visible ones are black anyway.
Old Sep 25, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Ok. . the engine. . the car. . when it's made. . ya know...at the factory ??. . It's grounded. They don't send it off with a "bad ground" They send it off with a general recommended, tested; known good ground. . It's grounded like it needs to be to work with the rest of the car pretty much forever. . . You can't do much to improve it. So . .. if you wanna spend the money and run wires everywhere, have fun, but it's not gonna do anything besides decrease the resistance to earth ground, which isn't necessary. the stock ground is nifty and does everything it's supposed to do and everything you could want a ground to do..
Now. . if you have 20 wires grounded everywhere, then, in theory. If the 1 that is there to start out with gets severed or something like that. . then you have some backups . .but other than that. . . why?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
2k2civic
Dec 6, 2001 09:41 AM
blackbullet
Dec 1, 2001 03:44 PM
