Cusco REAR Strut Bar
Originally posted by civicvtec1ps
yes sir. it will fit on 03 lx coupe
But other than those 2 little things, it fits like a glove.
why on the instructions is the only legible sentence say "MUST ONLY BE USED IN JAPAN" or some thing to that effect...hehe
but for real, u know the torgue specs for this beefy a$$ turd bar?
(nice bar thanx for the info and recomendations on it!!!!!!)
Torque specs for the tower bolts is 33 ft-lbs. For the bar ends, just make them tight as you can. I don't know the spec.
Its a celebration bitches!
?by any chance can you take a pic of what youi are talking about boilmaker
im going to get my big beefy bar put in probly on wednes day so i would like what i need to prep befor i slid it inthere, ex. proxy or some of sticky lube
this folder has all the pics I have from the install.
Click
I wrote a DIY in the suspension forum last spring when I installed it, it might still be there.
You're gonna need some deep sockets to get the tower bolts off, a few extensions help, make sure you've got METRIC Allen Wrenches (don't remember the size but its pretty big. The nut on the bar ends is 16mm.
have a screwdriver handy to pry off the wire cover (you'll see it when you get the carpet up).
If you want to use the body mounts, get nutserts and the bolts that go in there. Just go to the hardware store, 1 size nutsert (AKA T-nut) fits right in that hole with no play. Get some JB weld or Epoxy to stick them in.
Click
ahhh yes, i see the wire you have to move, its just a clip off on wire... but the bolt you are talking about is the upper one closest to the middle of the car?
holy ****, i put this bar on tonight, and all i can say is good god. this thing made more of a diffrence than any other part i have put on the vic. well worth the money imo..it was the missing link in my suspension. now al i need is to find a bad *** front sway bar and im good to go!!!
They are 150 shipped from www.machiii.net go to the 2002 RSX rear upper bar.
i put it in tonight but two of the holes didn't line up right? is that gonna be a problem? i already feel it handle better but im jus makin sure theres not gonna be a problem with it
fatih717171
Jul 25, 2016 06:22 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
