Sponsored by:
Sponsored by: CARiD
Apex'i V-tech contoller question?
Old Sep 18, 2003
streetglower's Avatar
I know there are other posts on the V-tech controller, but what does it do? Does it increase horsepower anyway? I know it makes your v-tech kick in faster, but what does that mean or do for our car? Someone please explain this product to me in detail so I know what it is? Thanks
Old Sep 18, 2003
Mr.Modify's Avatar
i thought it had something to do with like the fuel and everything?
Old Sep 18, 2003
I wish I knew what the hell it was and what it does?
Old Sep 19, 2003
come on I know someone knows the answer to this, someone has to have one?
Old Sep 25, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
it lets u turn your vtec at earlier rpm
Old Sep 25, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
1. it's vtec not v-tech
2. it lets you adjust when to switch from low cam to hi cam and back from hi cam to low cam (when vtec engages and when it disengages).
vtec engaging means a new set of cam gears are used and more air is sucked into the engine.... which brings us to number 3
3. the apexi' vafc is a vtec air/fuel controller which means you can adjust stuff in #2 and adjust the how much fuel is added or reduced from the stock amount at each rpm range in increments of 100rpm. SO this means if you set vtec to engage at say... 4500rpm (lower than stock value) then you would want to add more fuel at 4500rpm to make up for the additional air getting into your engine. this is all because your ecu still thinks vtec is engaging at stock value (~5500rpm) and does not apply addtional fuel to make up for the increase in air until 5500rpm. i highly suggest getting an air/fuel ratio gauge with the vafc so you can tell when your running lean/rich and by how much so you can adjust accordingly.
btw this stuff is explained in NUMEREOUS threads like you said. Please refer to those for more info.
Old Sep 25, 2003
civic01vtec's Avatar
Ur almost right on this one........When vtec engages, which switches to high cam, which in turn allows the intake valves to open farther which then allows more fuel into the engine, not air. The exhaust valves don't open farther, just the intake valves.
I dont' know the exact rpm which stock vtec engagement is, but i believe that mine is around 4200 rpm. The apex vtec controller allows u to set engagement from 3500 to 6000 rpm.
Old Sep 25, 2003
dj02's Avatar
make it easy one ur self go to the horse's mouth and read up.. http://www.apexi-usa.com/electronics...aloverview.asp
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
