problems, help quick!
Im installing my new intake and having problems, i cant get the hoses and the sensor off of the stock intake, im clampin down on the hose clamps with needle nose plyers and they wont come off still, one of the hoses seems to be a screw in which is really weird. Can somebody please help me? Also, when trying to get everything out im having a problem gettin the place with the filter out, you know down by the headlight, there is like a rivet or something holding it in, is this like a pop out deal or what? THanks!
Don't really know what you're saying. If you're installing it, there should be nothing by the headlight. The stock filter is on top of the engine. Everything either had screws or just pulls off.
It really is, the battery is in the top left. Things are way different. I got everything apart, except I need to figure out how to get the wheel well off, anybody have an idea how to get these little clip type deals out? Help Would Be Apprectiated@!
if your trying to get the resenator off you need to take the bumper off. that would be easier to remove than the wheel well. the bumper is really easy just a feww clips and like two bolts and pull.
Originally posted by 4bangin
he needs to remove the wheels well to get the cold air extension down the hole. on the 6th gens they sit inside the wheel well. those clips, the center part just carefully pry it out with a flathead screwdriver and it should just come loose and then you can pull it out.
beveragemp
May 25, 2015 07:11 PM
