Sponsored by:
Sponsored by: CARiD
injen CAI instructions
Old Sep 10, 2003
vincejm3's Avatar
vincejm3 is an unknown quantity at this point
The installation instructions didn't come with the Intake. I'm wondering if somebody here can tell me a step by step procedure to install the Injen Race Div CAI.
Old Sep 11, 2003
VTECTypeR's Avatar
Go to the DIY section. Theres a DIY for a AEM CAI its pretty much the same thing.
Old Sep 11, 2003
vincejm3's Avatar
Thanks. Didn't even know there was a DIY section
Old Sep 11, 2003
streetglower's Avatar
installation instructions for the aem intake really isnt the same for the Injen intake, the piping goes down under the bumper. and there are other modifications needed to be done.
Old Sep 11, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Remove bumper (see DIY for clear headlights)
Unbolt the stock intake resonator and air box. Make sure you remove the intake temp sensor from the air box before pulling it out.
Install the top pipe, then snake the bottom one through into the bumper cavity, you'll have to trim a corner off the battery shroud to get it in... no biggie. Don't tighten anything up until its all in and fits, bolt the bracket to the wire harness bolt on the right front corner. Put the filter on, plug in the IAT and the breather hose. If you haven't already, disconnect the battery, wait 10 minutes, then connect it back up, start the car, and just let it idle for 10 minutes. This resets the ecu. if you have no check engine lights at this point then you did it right, have fun.
Old Sep 11, 2003
HondaLuver's Avatar
Its a celebration bitches!
u don't need to take it off, just pull back the wheel well
silentz
Jul 9, 2015 08:16 PM
