Sponsored by:
Sponsored by: CARiD
header issues
Old Aug 8, 2003
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Question header issues
hey guys i am about to buy a header i have some questions has anyone ever had any problems with their header leaking like at the gasket or have to go back every so often and tighten up the bolts on the header to the block. or just any thing like that thanks for the info
Old Aug 8, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
I haven't ever had problems...Just torque the bolts to spec and you'll be fine
Old Aug 9, 2003
Weaponx12o's Avatar
you'll be fine, just make sure you tighten each bolt properly and get a new gasket when you install it.
Old Aug 9, 2003
runner1738's Avatar
you need a new gasket for a header, i just ordered a dc sports ceramic and wanted to install it but what gasket do i need to get?
Old Aug 9, 2003
orso's Avatar
orso is an unknown quantity at this point
depends on how many miles are on your car. if it is fairly new then you don't need to buy gaskets. unless you want to. but if you do then you need an exhaust manifold gasket and the donut gasket for the bottom of the header where it bolts to down pipe. this is for ex of course. if you have lx then the bottom gasket i have no clue of.
Old Aug 9, 2003
CapYoda's Avatar
Escaped Convict
even though you torque to spec.. you should check up again on it every 5,000 miles..
the header puts out excessive heat.. it'll loosen the bolts if you didn't torque it down to spec.. so check every 5-10K miles would be good.
if the gasket looks fine, you dont really need to swap it.
but generally its always a good idea. they're only 3-5 bucks anyway. (except the bottom donut gasket to the collector/downpipe/cat, you might not want to just swap that.. Honda'd want $20 or so bucks from you for it.)
Old Aug 9, 2003
runner1738's Avatar
i think i have like 12,000 miles on my car and i have an ex, do i need new ones?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
EK_Eddy
Jun 6, 2015 07:31 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
ayzan
Dec 12, 2001 10:45 AM
DC5@EM2
Dec 4, 2001 07:53 PM
