Pedal help, ASAP!
www.AbsouluteDriven.com
Pedal help, ASAP!
Ok, i'm putting on my sparco pedals in like an hour - I got the kind that you have to drill on. Everything should be fine for my clutch and brake. Im a little worried about my gas pedal. It seems like it is all plastic and I wont be able to get the bolt behind it. Has anyone done this before? does that plastic come off? anything?
the gas pedal dosen't come off, i don't think.....
i got some rizo, and the gas pedal piece goes over the stock, the brake and clutch went over the little metal pedals, but the gas doesn't come off.....
Search and Learn
you have to either buy long screw that can go through gas pedal or just use tiny screws that can hold pedal on stock gas pedal.
you do not need to remove anything for gas pedal,
i removed stock rubber from clutch and brake pedals then made holes.
sesi
Oct 1, 2015 02:03 PM
juicetayne
Sep 30, 2015 11:02 AM
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
