OEM side skirt installation ????HELP
does anyone know how to install the OEM side skirt. i just bought a 2nd hand. i thought all the holes are pre drill. but when I look under. they weren't there. it seems like it doesn't fit well.
i thought there is a post about this from the past. but can't find it. PLEASE HELP!!!!!
i hope this helps
http://www.hondaautomotiveparts.com/.../19813_01.html
it's not bad at all, you need the mounting hardware, maybe try ebay or majestic honda, handaaccessories or even hondawerx.com? I had a second set cause they sent me two left sides at first, but I screwed up one of them and needed to use the secondary hardware.....there's like four tape mount "rails" 2 on each side that the skirts slide into, then bolt on, it's really easy
