2007 Navi Package Aux Issues
Old Jun 21, 2017
crombiek's Avatar
crombiek is an unknown quantity at this point
Hello Everyone,
Like many I have been having problems with the aux. When I drive speakers cut in and out; but when on FM/AM/Radio it does not happen. Even when I switch immediately when the speaker cuts out it works fine with other inputs. The only way I can get it to go away is smacking the dash and getting lucky or sometimes plugging in a phone to the 12V.
I have tried multiple cords.
I have replaced the aux jack.
I have removed the navi unit and reconnected all the main plugs.
What else could be problem?
Old Jun 21, 2017
Re: 2007 Navi Package Aux Issues
smacking the dash
Flaky head unit? (internal problem)
Old Jun 29, 2017
crombiek's Avatar
I dont think it is the head unit. I noticed specifically if I push in on the front of dash it works. I smack it so the connection will stay. I'm thinking it has to be one of the pins going into the head unit, other than B22P which pin connector could it be?
Old Jun 29, 2017
Pull it out of the dash and check all the wiring on the back?
Old Jun 30, 2017
crombiek's Avatar
It is definitely the 22P connector pin. The connections must not be tight enough on the female side.
