Tried USB Aux Cable, Car Now Dead
Old May 29, 2017
MajTom7's Avatar
MajTom7 is an unknown quantity at this point
I prepared a USB flash drive for my CR-V. It worked there so I tried using it in my 2009 Civic. I had no idea that there was a USB aux cable in my Civic until yesterday. So I attached the flash drive, turned the ignition on accessories, then turned on the radio. It played from the drive for a few seconds before the radio went dead. I turned the ignition off then tried to start the car. Nothing other than the instruments coming on and cycling... The car was working fine until then.
Any thoughts? Thank you.
Old May 29, 2017
Re: Tried USB Aux Cable, Car Now Dead
Weak battery.
Jumper cables/jump start or charge up the battery
Old Jun 1, 2017
mac25's Avatar
Dr Krieger of Modification
Op you must have had a virus file on the usb drive that made it to the vehicle ecu...
jk
Old Jun 2, 2017
MajTom7's Avatar
Dealership said it was the battery. Replaced it and everything seems to be working... but I will not touch that cable again LOL
Before I copied over the music files, I had only used the drive as backup storage. It came up clean when scanned.
