srs light on
Old May 11, 2017
canboro905's Avatar
canboro905 is an unknown quantity at this point
srs light on
2007 honda civic coupe thats had the side airbag curtain replace ,the steering airbag , the seat belt buckle, and the srs module,all used parts ,srs changed twice, it keeps coming up with 27 10 ,31 10, 33 10 codes. dealer is telling us we nee all new parts?? (it was at the dealer) clear codes and hey come back. dealer has reset module also. Anyone have anything on this ?
Old May 12, 2017
Re: srs light on
27-10, open in drivers buckle tensioner circuit
31-10, open in drivers side airbag inflator (the one in the seat)
33-10, open in left side curtain airbag inflator
Were all of the used parts verified as good before installation? (seat belt buckle tensioner that's been fired can be difficult to see until you have a good one right next to it to compare with)
Are all of the wiring connectors correctly seated and actually locked in place? Easy to stick SRS connector halves together but not actually be connected.
Got wiring damage that you didn't see?
You can use a 2 ohm resistor as a substitute for an inflator detonator to figure out if the control unit and wiring are ok or not
