Switched hot wire
Old Mar 24, 2017
Sagmack's Avatar
Sagmack is an unknown quantity at this point
Switched hot wire
2013 Civic EX ...Need to find an ignition switched hot wire under the dash. Any ideas as to wire color and location
Thanks
Old Mar 24, 2017
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Switched hot wire
What amount of current flow are you looking for? What device are you looking to power? And finally you are in the wrong forum.... a 2013 civic is 9th gen not 10th, but you should be able to get an answer pretty easily.
Old Mar 24, 2017
Sagmack's Avatar
Powering a auto dim mirror with compass and HomeLink. Sorry about the generation being wrong......I'll post this in 9th Gen too. Thanks
Old Mar 24, 2017
Sagmack's Avatar
Mirror auto dim with HomeLink
Installing a auto dim mirror with homelink.
have it in and battery and groumd wire hooked up. However when I was looking a ignition switched hot wire I hit a snag.
Any ideas as to this ignition switched hotwire. I ran a wire from the mirror to the fuse box area. Bit didnt want to mess with removimg the fuse box if I fidnt have to. Any ideas.
Thanks
Old Mar 24, 2017
mcnoople's Avatar
You could have just sent a message/report and the mod team would have move it for you. To correctly wire an autodim mirror you would also need an input from the reverse light circuit. The auto dim mirrors are designed to turn themselves off in reverse.
But lucky for you that honda designed these cars to be able to use powered rear view mirror. Wiring an auto-dim/homelink would be little different from adding the factory compass mirror. I strongly suggest a legitimate "gentex" unit for the mirror. They are OE quality and used by many of the car makers as original equipment, plus they own the "homelink" brand.
I was going to write good instructions on which wire to use, but I got a last minute project at work and don't have the time to finish this post. If you go to your local dealer they should be able to give you installation instructions on the compass mirror. There is also a honda website that provides those same instructions for owners. I think it is something like honda owner link, but I can't remember and have to start my weekend.
Ezone will likely pop in and fill in the blanks I have left.
Old Mar 24, 2017
Re: Mirror auto dim with HomeLink
Google 'Fuse tap'
This image said autozone on it...so you should be able to find this easily.
Old Mar 24, 2017
Threads merged, and moved to 9th gen area
