07 civic si Stock Radio cuts off and on when using the defrost or A/C
07 civic si Stock Radio cuts off and on when using the defrost or A/C. But once the radio comes back on it's like nothing happened. Memory is still stored, and the station and volume return to what they were.
Re: 07 civic si Stock Radio cuts off and on when using the defrost or A/C
You might try removing and replacing the involved fuses. Make sure your battery cables connectors are tight and clean. The defrost and AC uses the same blower motor, so that fuse, circuit is suspect. Are they any other electrical issues that might indicate you have a tired out alternator? Just some thoughts, better with the mechanical than the electrical. Send a private message to Ezone he is a highly knowledgeable long time Honda Mechanic.
I dunno..
Assuming system voltage is not low while running.....
I might pull the radio and monitor power sources and the grounds, watching for wild fluctuation or dropouts as the AC or defrost are used.
Once you know why the radio is cutting out, you can trace out the source of that problem.
I assume you mean front defrost, not rear?
carid
Part and Product Reviews
Dec 15, 2016 07:41 AM
Mc7602
Sep 17, 2015 02:01 PM
1028CiViC
Mar 21, 2002 11:29 AM
fordfocussucks
Jan 25, 2002 09:04 AM
