Voice command isnt responding
Old Jan 19, 2012
SumterSi's Avatar
SumterSi is an unknown quantity at this point
My voice command system isn't responding to my commands at all. It's as if the mic wasn't picking up. Anyone know where the mic plugs are or places I can check? Is there a module that controls the voice commands? If so where is it?
Car is a 2009 Civic Si with navi.
Thanks for the help!
Old Jan 19, 2012
Re: Voice command isnt responding
Get it to the dealer before warranty runs out!
Old Jan 19, 2012
The mic is in the center of the front dome light set. 3 wire connector, green.
HTH
Old Jan 19, 2012
SumterSi's Avatar
Too late, car has a rebuilt title due to an insurance job
But how do you get to the 3 wire connector? do i have to tear apart the area where the front dome light set is?
Old Jan 19, 2012
Pop the lenses out, there is a screw behind each side. If there is a sunglasses holder, there are 2 screws behind it too, look with a flashlight after you open it.
Old Jan 20, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Old Jan 20, 2012
SumterSi's Avatar
Is there is a module in console or somewhere that controls that? Or if anyone knows where mics wires go to?
Thanks for the help so far guys.
Old Jan 20, 2012
FIRST STEP must be checking for body system codes with the HDS scantool. Before taking crap apart and causing even more false codes.
Continuity testing from the back of the audio unit to the mic itself might be next, depending on what info can be garnered from the proper scantool.
Wiring runs thru a large connector under the center console, and another large one below the dash fusebox. If nobody has done any work in the areas, then the scanner is the first tool to use.
Old Jun 13, 2012
SumterSi's Avatar
Update: bought a new microphone thinking that would be the problem and nada, even with new mic it wont pick up anything i say! Wtf
deanaZoom
35
Sep 19, 2015 12:22 PM
JMKendrick
Sep 16, 2015 06:17 PM
Jrosa
Sep 14, 2015 08:24 PM
mendy
Aug 30, 2015 02:43 AM
