2007 Honda Civic Si - ECU Pinout/Speed Reference Signal
Old Jun 1, 2007
MaxRoberts22's Avatar
MaxRoberts22 is an unknown quantity at this point
Lightbulb 2007 Honda Civic Si - ECU Pinout/Speed Reference Signal
I am installing a new headunit in my 2007 Honda Civic Si. The headunit utilizes several car signals for operation. One signal is difficult to find.
Since the headunit performs navigation, it needs a car speed reference signal. Does anyone have an ECU pinout or know where I can tap into the car's speed reference signal?
Old Nov 15, 2007
unplugged's Avatar
unplugged is an unknown quantity at this point
Re: 2007 Honda Civic Si - ECU Pinout/Speed Reference Signal
run a wire to a non-common fuel injector wire (tach signal).
Old Nov 15, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Although a non-common wire @ an injector will give you a great engine speed signal, it's not quite the same as vehicle speed.
I realize this post is very old so you probably won't get this, but. Since you have an Si you're lucky. You can find it as the blue wire next to the purple accessory wire at the radio harness.
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
