2006 Civic EX Coupe P0128 Code
So today I was driving down the road and CEL came on my 06 Civic EX with AT, after scanning the code it's P0128.
Usually temperature gauge on the ODO shows 3-4 dots on the highway and they rise to halfway, once I am in stop and go traffic.
I was literally thinking about it, that there's possibly a problem with T-stat since it was brutally cold in last few days and car was usually showing 2-3 dots on highway, but NO CEL.
I think thermostat is stuck open and needs to be replaced, that's why a CEL. Anyone has any other ideas or advice?
Thanks very much.
Thanks very much.
Re: 2006 Civic EX Coupe P0128 Code
Three possible and common issues come to mind right away:
1) Bad thermostat/low coolant/wrong concentration
2) the temperature sensor in the bottom of the radiator may go bad or become inaccurate, also common is loose and corroded wire terminals for that sensor causing high resistance and skewed reading by the PCM.
(Rodent damaged wiring is common in my area too.)
3) Software update for false P0128 code.
For info on #2 and 3, see the TSB in this link: http://noes.net/09-092.pdf
Thanks EZ, here are my thoughts and response. What's your advice?
1-I am suspecting bad T-stat, it has Honda Type 2 50/50 in it. Coolant is good and full, check radiator and reservoir too.
2- Not sure about it?
3- Car has been maintained at the dealer until 2016, is there any latest/recent update for software and how can I make sure it's not software? BTW, my key fob randomly doesn't work which I suspect is bad battery, in one of the forum thread noticed someone saying it's due to software issue, no idea though?
1, 2: The code generally points to a thermostat, but that's not the only possible issue represented by the fault code.
Those other issues mentioned that result in the same code have been equally common IMO, if not more common.
That TSB I linked, did you read it?
If no obvious issues are found with the radiator temp sensor, then you might toss a Honda stat at it. (I don't like aftermarket)
Looked at the troubleshooting guide for P0128.....In my mind I'm reading and mentally calculating how much time they want to waste...when instead you could toss a stat in it in 10 minutes and see if the code stays gone LOL
3) We are not supposed to just do software updates without a reason, so unless software was updated to address some other issue in the past, there's a good chance it may not be current.
The dealer level scanner can display the current software version installed for engine and transmission, and if it matches or is newer (higher) than what's listed for your particular car in the linked bulletin, then an update won't help this issue..
PS) Not necessarily. Dots don't tell the actual temperature in degrees, and the gauge display is heavily buffered.
Most scanners and apps will show you a value for ECT1 which is the temp sensor in the engine, but few can display the temperature value for ECT2--that's the sensor in the radiator.
Yes, I did read it. Thanks for sharing TSB.
For now, I am planning to put a new T-stat and see what happens. Do you think it's a sensible move(https://www.civicforums.com/forums/1...-question.html, https://www.obd-codes.com/p0128)? Since I think car still has original T-stat.
BTW, can I restart ECU by removing -ve cable and see what happens? I mean, how long it'll take for the code to come back again.
Is there anything particular I should be aware of while replacing T-stat, seems fairly straightforward.
One more thing, can I test ECT1 and ECT2 sensors and corresponding temps with any OBD scanning tools? Like I can get from autozone and these places as a rental/loaner one?
And can ECU be upgraded(if it's needed) without a dealer or no(http://www.8thcivic.com/forums/mecha...28-code.html)?
Not sure, why 2 part numbers? https://www.hondapartsnow.com/oem-ho...75234&Filter=()
I just googled the bulletin, I don't ever link service info directly but I will google search and link info I find that others have posted on the net
A service bulletin never means a repair will automatically be covered by warranty.
Warranty only covered a repair if the car was "in warranty" at the time the repairs were needed.
As I already said, I'd be checking the condition of the wiring and temp sensor in the bottom of the radiator first.
But yeah, the stat is quick and easy to change. I'd use a stat from Honda myself, despite the price--I know I can depend on the quality.
BTW, can I restart ECU by removing -ve cable and see what happens? Battery disconnect will erase PCM fault codes....and lock up your radio if it is an anti-theft type. Make sure you have your unlock code handy.
You don't have your own code reader? I thought all code readers will also erase codes.
Factory unit is simple...Unbolt and remove.
Wrap the new gasket around the new stat the right direction,
Make sure the jiggle pin is centered in the gap,
Insert the assembled stat with gasket in the hole with the jiggle pin at the top.
Assemble, fill, burp cooling system.
Literally 10 minutes or less, not including time for warming up the engine afterwards and cleanup.
Carry on with life, knowing the factory unit is probably gonna last another 100-200k miles. If the code comes back, you can be pretty dang sure it's not a bad stat.
Installing an aftermarket? Too many possible ways to go wrong for me to guess LOL (I've seen a lot over the years)
If you install one and the code returns, you won't really be assured it's not a faulty new stat---instead of any of the other possibilities.
(I once installed a trusted well known brand aftermarket thermostat in a freshly rebuilt engine in one of my old GM cars. Stat opened about 40 degrees too early, had no heat on the first test drive--and it was winter. 2nd stat, same brand, lasted less than 3 months.)
BTW, was this work covered under warranty at that time?
For now, I am planning to put a new T-stat and see what happens. Do you think it's a sensible move(https://www.obd-codes.com/p0128)? Since I think car still has original T-stat.
Thanks so much EZ, as usual.
Actually, I do have unlock code for the radio but I'll try to erase the code from OBD scanner.
My plan of action is to put the car on jackstands and see the bottom sensor and it's wiring, I might as well clean it and put some dielectric grease on it and top sensor too.
Definitely going OEM, at least one less thing to worry about! I am planning to pull trigger on either of these two: (
https://www.amazon.com/gp/offer-listing/B00IMLBDCI/ref=sr_1_1_olp?ie=UTF8&qid=1515900844&sr=8-1&keywords=19301-RNA-315&condition=new ) OR (https://www.ebay.com/itm/Genuine-OEM-Honda-Civic-Thermostat-w-Gasket-2007-15-EXC-Si-Hy-19301-RNA-315/112645816375?hash=item1a3a36c037:g:uDkAAOSwldRaD2Jm:sc:USPSFirstClass!20109!US!-1&vxp=mtr)
Actually for anyone also 'looking or searching' here's one helpful and very detailed video:
Not made by me. Lol
I'll report back in a few days, weather here is brutally cold. DANG!
Not made by me. Lol
Not made by me. Lol
Not made by me. Lol
But from what I have seen, few scanners display data for the radiator temp sensor (ECT2).
As always, makes sense and thanks so much EZ.
I'll try to analyze the data first and then see what happens, will update the thread.
Again, thanks for confirming the part number too, Honda(Or can I say CAR)GURU
By any chance, does anyone know if they both are same?
https://www.ebay.com/itm/Genuine-Hon...!US!-1&vxp=mtr
Because it looks like all dimensions and everything is same, I have one laying around from an older accord.
No clue here, all I can see if different part numbers.
What's the temp rating on it?
Compare to the right one for your car
Another way I compared it, I actually went to Rock Auto website and it's listing same T-stat for my older Accord, as well as 06 Civic. Also, showing part numbers exchangeable too. Like 19301-PAA-306 and 19301-RNA-315.
But I wanted to be sure, even dimensions are same too.
But I wanted to play safe
Stat for an older car might be stamped 82*C (180f) on the bottom......
newer cars might need to be 88* or 90*C (190-195f)
Check yours?
My own car runs steady 202f on highway trips (ultragauge), I think its stat is stamped 88 (I CRS, LOL)
Check yours?
Thanks again for your help.
BTW, T-stat for older accord is 77 degree Celsius or 170 in Fahrenheit.
So no bueno and ordering an OEM for 06 Civic.
Curious minds never stop, lol
Now question, have you heard of Aisin thermostat, as well as Tama Thermostats for Honda?
http://www.rockauto.com/en/moreinfo....588308&jsn=148
https://www.ebay.com/itm/Honda-Tama-...5/251512991496
If the stat is really faulty it's probably going to run below operating temperature (if you drive long enough to reach it in the first place) or take longer to warm up than it should.
Right now it's below +3F here, I can drive all over town and never reach operating temperature. I did just that on the way home from work (+6F), a good 40 minutes of driving in town (under 35 mph) and the engine never got above 165f.
But it's because I have the heater fan on full blast, and the heater pulls heat out of the engine faster than it can burn gas to make heat. I have to hit the highway or run it at high RPM, or turn my heater off before it will reach operating temp.
That's exactly the situation here too, brutally cold.
I'll keep the car parked and only drive after replacing T-stat and then see what happens and hopefully no more CEL. Otherwise, more troubleshooting.
Replaced T-stat with an OEM and definitely happy!!!
No more CEL and all is well, drove nearly 15-20 miles after clearing the light and all is well.
Hopefully it'll stay like it. Thanks for all the help EZ, as usual
HCivic2006
Jul 29, 2017 06:06 PM
JasonHZS
Feb 11, 2016 05:26 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
