Using Diesel Fuel to unclog transmission
Old Aug 8, 2016
suzyannnchong's Avatar
suzyannnchong is an unknown quantity at this point
Has anyone ever tried using diesel fuel to unclog a transmission to unstick the the clutch ?
Old Aug 8, 2016
Re: Using Diesel Fuel to unclog transmission
NO.....Hell no.
What's the real problem here?
Clutch in a manual trans? What is stuck and how?
Hydraulic system parts will be ruined by petroleum products (diesel, oil, etc.).
Did the clutch fluid leak out? Find and fix the leak. Refill with DOT3 brake fluid and bleed air from the system.
Old Aug 8, 2016
the problem is , I took my car to a service station to get my fluids checked , I didn't have any transmission fluid so the guy suggested I let him put some in there the car was running while he put the transmission fluid in the first mistake was that they put the wrong transmission fluid in and the guy acted as if he didn't know what he was doing , the car wouldn't go it would go into different gears but it would move just idle , so they removed the transmission fluid and tryed again still wouldn't work .
Someone suggested that if you put a little bit of diesel in the transmission hole where you put the transmission fluid to flush it and unclog my clutches or gears that's inside of the transmission and replace my strainer
Old Aug 8, 2016
GolNat's Avatar
Prelude Owner
So the transmission worked before you went to said service station and now it won't after they put the wrong fluid in?
Fuel does not belong in the transmission!
Old Aug 8, 2016
That's correct , we're not going to put gallons just enough to try to unclog the build up cause can't you use brake fluid as well ?
Old Aug 9, 2016
Post #1 and #3 indicate whomever touched your car had no clue what proper procedures are, made multiple mistakes, never bothered to check published service information to find standard procedures, and any small claims court judge would probably decide that this shop now owes you a properly operating transmission.
Based on the above, I would never trust nor allow said shop to install that transmission, I'd make them cover all expenses (including tow truck fees) for a real Honda dealership to replace the transmission correctly with a factory authorized remanufactured transmission, complete with 3 year/36,000 mile warranty.
Also, another HELL NO on the brake fluid.
shiguiy
Aug 1, 2016 11:40 PM
DAVID_396
Aug 1, 2016 01:09 AM
FistRock
Jul 31, 2016 03:24 PM
whiteazn
Jul 28, 2016 08:48 AM
singh_si
Jul 24, 2016 08:05 PM
