2009 Civic No start/no crank
Old Apr 1, 2016
mproost's Avatar
mproost is an unknown quantity at this point
Hello everyone-
My 2009 Civic LX-S has an issue I cannot figure out. A little while ago my car seemed like the battery(3.5 years old at the time) was weak and the car started hard. So, I got a new replacement battery and the car seemed OK, but then a few starts later it stranded me in the Costco parking lot and barely started when hooked up to a jump box. I got a new battery and it started twice on its own and then needed to be jumped and barely started. It started once more and then would barely turn over but not start again even when jumping it. The battery was testing low voltage on my basic multi meter. I replaced the battery again and the car will not turn over when attempting to start it with the jump box or on its own. The voltage drop is almost 2 volts when the key goes to the start position.
I have done the basics checked all battery connections etc. Where do I look from here?
I am thinking starter or solenoid, can someone point me to an easy way to test that? I would prefer not to go to the dealer.
Thank you!
Matt
Old Apr 1, 2016
Re: 2009 Civic No start/no crank
Your descriptions are kinda vague to me, so I'll say that many people have had to replace their starters.
Starter and starter circuits can be tested (sometimes not easily) before you take it off the car.
You can use a heavy duty ammeter and voltmeter (V.A.T. tester?) to evaluate, if you know what you are doing.
Or remove it and have it checked.
Aftermarket remans are about 80% crap.
Hani4g
Oct 31, 2015 02:09 PM
R Steele
Oct 22, 2015 05:09 AM
Mv7fd
Oct 12, 2015 05:09 PM
Handsonme
Sep 4, 2001 06:31 PM
