Brake issues
Old Nov 1, 2015
Stussey21's Avatar
Stussey21 is an unknown quantity at this point
Brake issues
Hello I have an 06 civic lx and the brakes start making a very weird rubbing sound after a while of driving, it only started happening after I changed the brake pads so I was wondering if anyone had this problem or any fixes for it, thanks in advance
Old Nov 1, 2015
Mad Dog Tannen's Avatar
Re: Brake issues
Check for uneven wear between right and left brakes, you may have a stuck caliper.
Is it a grinding sound?
Old Nov 1, 2015
Stussey21's Avatar
Yeah but it's only at the end of a stop around 15-0 and only after the brakes heat up
Old Nov 1, 2015
Re: Brake issues
probably a stuck piston. look for uneven wear.
Old Nov 1, 2015
Re: Brake issues
And it gets louder if you step on the pedal harder, right?
Less noticeable if you brake very gently?
It's normally caused by the friction compound the pads are made of.
Sounds like you probably got some cheapo brake pads.
Upgrade to better quality, ceramic, or factory pads?
Old Nov 2, 2015
Stussey21's Avatar
Yes exactly and they're the best I could buy they cost me 60 at autozone 😔😔
Old Nov 2, 2015
Re: Brake issues
Damn, for that much money you could have had a set of Hondas pads from a dealer at normal retail price, USD $63.xx.
Cheaper on the internet, plus shipping.
Old Nov 2, 2015
Stussey21's Avatar
Is there anything I can do to fix this tho I hate the sound and I hate knowing there's something I need to fix and not knowing what the hell to do
Old Nov 2, 2015
Re: Brake issues
Would you agree the issue probably has to do with the pads you installed?
Were they installed incorrectly?
Is it a bad set of pads?
Got warranty?
Exchange for something completely different?
Get your cash back and go with factory?
The noise I was thinking of has been described as a loud "crunching" noise...or a rapid popping noise.
Mostly happens after the brakes are hot and can get quite loud with hard pedal pressure.
Abb0nz
Jun 23, 2015 06:10 PM
raynist1
Jun 23, 2015 02:03 PM
xeroid
Jun 19, 2015 02:24 PM
Andy
Dec 29, 2001 07:32 AM
Sparty
Nov 15, 2001 04:55 PM
