Switch
Old Aug 18, 2013
Pratheesh's Avatar
Pratheesh is an unknown quantity at this point
Thumbs down Switch
Hi
I have a Honda civic fitted with Surround view camera system. this has been triggered by the reverse gear( as usual). but I need to add a switch so that I can view the cameras while iam driving when I press that switch.
Please any of you guys have any idea of what tyoe of switch should I go for to get this fixed.
thanks
Old Aug 18, 2013
GolNat's Avatar
Prelude Owner
Re: Switch
So you want to be able to use your rear view camera anytime by turning on a switch?
Do you still want it to come on when you shift into reverse also?
Old Aug 18, 2013
Re: Switch
Sounds like there's either a magnetic switch or a relay that's tapped into the circuit for the reverse light.
If it's a magnetic switch, replace the magnetic switch with the rocker/push button switch of your choice
If it's the latter, have the relay coil take a signal from any hot wire with an in-line switch instead of the reverse light circuit.
Oorrrrrr... If you want it to have an "auto-on while in reverse" feature while still beig able to turn it on/off at will, use a 5-pin relay and wire it as such:
85: reverse light circuit
86: any ground
87a: from battery pos terminal or +12vdc line with an in-line switch
87: from battery pos terminal or +12vdc line, no in-line switch
30: to monitor power
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Klame9420
Sep 7, 2015 10:03 PM
junkyardguy
Sep 2, 2015 06:07 PM
